Help with my MT121 |
Chewit
Registered User Joined: 18 May 2020 Location: Dorset Status: Offline Points: 39 |
Posted: 27 July 2020 at 9:22pm |
Loaded my MTs with PD123er and P-Audio BM-D750 2”
As they are BI amp? Would I need to power them with an amp EACH! Or I believe I could run them of 1 amp if I was to run it all in 4ohm, but the compressions are not meant to be run in 4ohms I believe? Any help would be great, also suggestions in some amps that would be good for me to use :) Thanks
dlyxover
Old Croc Joined: 14 June 2007 Location: Liverpool Status: Offline Points: 1502 |
Yes, you need 2 channels of amplification and processing (crossover, eq, time alinement)
If you have a passive crossover you can run them from 1 channel of amplification. You will need a crossover of some sort or you will blow your compression driver.
In the Truth there is no news, and in the News there is no truth
FOO
Young Croc Joined: 23 December 2018 Location: Denmark Status: Offline Points: 815 |
You need a Amp for the 12" and one for the 2". Simple as that :)
Unless you go mono and link your MT121 together. Then you can run the 12" of one channel and the 2" of the other channel.
Chewit
Iv got a Vector dsp204
Chewit
Get a 500w amp for comps and get a 1200w amp on mids x
levyte357-
I've used mt121s for many years.
If on budget, suggest you get, Used dbmark dp28 LMS, Used QSC PLX3402 for driving 12s, Used QSC PLX1602 for driving 2" Compression drivers. Those amps comfortably drive of the above 2-3x drivers per channel, and QSC 1602 is class AB, which means nicer sound.
