  New Posts New Posts RSS Feed - Help with Tannoy 15" subwoofer i/d.
markie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote markie Quote  Post ReplyReply Direct Link To This Post Topic: Help with Tannoy 15" subwoofer i/d.
    Posted: 24 February 2019 at 6:28pm
Ages ago I picked up a Tannoy subwoofer. It was a 30 quid eBay special and in a bit of a state. Originally it was an active, but the amplifier had gone west. The face plate was still present but the only i/d is the Tannoy logo and "Bash" in one corner.
It has a 15" dual voice coil driver, cast frame and a heavy rubber surround.
The cabinet was square with 4 ports, one in each corner. cabinet was covered in a black Ash type (plastic) veneer, and was similar to some 12" ALF subs I have, so may well be one of their commercial models. Unfortunately I scrapped the cab, and although I took the measurements I lost them.
Can anyone help with an i/d???
Thanks in advance.
scottylaroq View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote scottylaroq Quote  Post ReplyReply Direct Link To This Post Posted: 02 March 2019 at 5:59am
i think bash still makes plate amps, maybe worth giving them a call for a replacement amp?
otherwise get a DATS and just measure t/s yourself
WessexAudioMan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WessexAudioMan Quote  Post ReplyReply Direct Link To This Post Posted: 02 March 2019 at 12:52pm
It was part of the Revoltuion range that Tannoy did if i remember correctly.. Tannoy R-Sub or Revoltuion 15 Sub i think the model was. Really good sub for HiFi and home cinema. We use to sell them many moons back when i worked at Tannoy Dealer/shop, can remeber them well as they were huge for a HiFi subwoofer :)
Post Options Post Options   Thanks (0) Thanks(0)   Quote markie Quote  Post ReplyReply Direct Link To This Post Posted: 02 March 2019 at 2:17pm
I actually contacted Tannoy with pics of the driver and they said it was from an SB15.
I since managed to get pics and measurements  of the old cabinet.......... I was wrong about 4 ports, it only had 2 and the finish was a grey/black sort of grit type laminate.
The main thing is I have the dimensions now so can get on with building a new cab. I picked a BK Electronics OMP sub amp (500 watts), so that should make a decent noise.
