  New Posts New Posts RSS Feed - HELP
HELP
TRE4U2NV View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRE4U2NV Quote  Post ReplyReply Direct Link To This Post Topic: HELP
    Posted: 23 July 2012 at 2:12pm
HELP both my hardrives [external ] have both disappeared from my computer tried to restore to earlier time
not working
windows xp sp3
tell whats gone wrong and how to fix it please
Embarrassed
levyte357 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357 Quote  Post ReplyReply Direct Link To This Post Posted: 23 July 2012 at 2:16pm
Do you have alternate  pc?
Connect them to that, confirm if data still present and in order.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRE4U2NV Quote  Post ReplyReply Direct Link To This Post Posted: 23 July 2012 at 2:23pm
They show up in device manager just not in my computer
on my xp machine and my shiny win7 but cant get into them Angry
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357 Quote  Post ReplyReply Direct Link To This Post Posted: 23 July 2012 at 2:24pm
Erm, did machine crash or was rebooted, with them attached, without being shutdown first ?
If you're lucky, maybe Partition tables are bit garbled, but data still readable from Linux.
Is your "protection" suitable, and up to date ?
Edited by levyte357 - 23 July 2012 at 2:26pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRE4U2NV Quote  Post ReplyReply Direct Link To This Post Posted: 23 July 2012 at 2:27pm
havent got foggyist went out last night left it running came back it was still running minus two drive letters
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357 Quote  Post ReplyReply Direct Link To This Post Posted: 23 July 2012 at 2:34pm
Where the external drives formatted as NTFS or FAT32 ?
If you have secondary pc, possibly an idea to retrieve hard disk from external case, open up pc, and connect secondary data cable/power cables directly to drive, to confirm if drive or external drive case malfunction.
Edited by levyte357 - 23 July 2012 at 2:36pm
andycw View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote andycw Quote  Post ReplyReply Direct Link To This Post Posted: 23 July 2012 at 2:43pm
How old are the drives?
Could be some bad sectors.
No Bass No Fun
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRE4U2NV Quote  Post ReplyReply Direct Link To This Post Posted: 23 July 2012 at 3:18pm
think they were fat32 had them about 1year and a half
one is a wd 500gb the others a seagate 1tb got a freeagent running fine and a seagate expansion running ok
mini-mad View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mini-mad Quote  Post ReplyReply Direct Link To This Post Posted: 23 July 2012 at 3:57pm
unplug em... wrap them up tight in a bin linner so theres more or less no air, with the psu...a nd chuck them in the freezer for 30mins...
get them back out plug them in and see what happens.
no its not a nuts idea, iv done it a number of time and has worked more often then not. externals dont sleep and driving them at 100% for a few hours all by them sevles and then buggering off out isnt a nice way to treat you hdd's...
give it a try, it wont damage them... dispite the amount of abuse im about to get.
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357 Quote  Post ReplyReply Direct Link To This Post Posted: 23 July 2012 at 5:37pm
+1
All hail, Genghis Trev, torturer of HDs.
http://www.lovehkfilm.com/panasia/aj6293/genghis_khan.jpg
Edited by levyte357 - 23 July 2012 at 5:46pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRE4U2NV Quote  Post ReplyReply Direct Link To This Post Posted: 24 July 2012 at 2:33am
lol HELP all offers no matter how crazy
audiomik View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote audiomik Quote  Post ReplyReply Direct Link To This Post Posted: 24 July 2012 at 3:09am
Download an iso image of the GParted Disk Utilities live Boot CD and make a CD of it.
Boot your PC directly from the GParted CD (not into Windoze) and with the external Hard disks connected.
Follow carefully the on-screen instructions to find your partitions on the external drives.
There are a number of different utilities within this CD to either test your Hard Drives, recover lost partitions or files within corrupted partitions.
This Software is quite 'powerful' so be careful!
If the USB links fail, then try removing the Hard Disks from the external boxes and connect them directly into your PC.
You can disconnect your Windoze Hard Drive when you do this as it is completely unused for the GParted Software to work on your other drives.
Good luck!
Mik
Edited by audiomik - 24 July 2012 at 3:11am
Warning! May contain Nuts
plus springs, washers, screws, etc, etc.
