Forum Home Forum Home > Speakerplans Classics > Other Classics
  New Posts New Posts RSS Feed - Hi speaker geeks
Hi speaker geeks
 Post Reply Post Reply Page  <12345 16>
Peter Moller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peter Moller Quote  Post ReplyReply Direct Link To This Post Posted: 11 November 2009 at 9:33pm
Originally posted by bassmattmatty bassmattmatty wrote:
Stasys is too big for me as I’m only 5'3 Embarrassed which doesn't help.
Line array systems can be hung from head height with the right stands and as I said before I really like the look of them. For the record I have never heard a bad line array
Linearrays are not the solution to all your problems.. trust me..
Example: Local venue, 800 punter capacity:
per side:
6* d&b Q1, 6* Q sub, 1* Q7 infill
To drive this, you need 3* D12 amps per side...
Total setup time with a 2 man crew:
15 minutes to prep rigging and hang the points
10 minutes to calculate angles etc.
10 minutes to assemble array
10 minutes to stack subs
10 minutes to tweak
An equivalent system could be 3* Floodlights + 3* TSW718 per side
This rig can be groundstacked and total setup time would be about 20 minutes with a 2 man crew..
loadin times would be drastically reduced aswell  ( unless you have to load in on a flight of stairs )
the conventional system would involve having to move a total of 12 cabinets and 2 racks.. the linearray system would involve moving 26 cabinets and 2 racks..
real phone no: +45 four zero six two four four nine eight ( using obvious anti phone spam encryption )
bassmattmatty View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bassmattmatty Quote  Post ReplyReply Direct Link To This Post Posted: 11 November 2009 at 9:34pm
That just my take on things and what I’ve been told by others
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peter Moller Quote  Post ReplyReply Direct Link To This Post Posted: 11 November 2009 at 9:34pm
Peter looking back on your post how does a driverack 260 x1 Labgruppen FP3400 and x2 Labgruppen FP6400 drive x10 JBL VRX 932 midtops and x10 JBL SRX718 subs ?
2 ampracks each containing the stuff you mention..
backlash View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote backlash Quote  Post ReplyReply Direct Link To This Post Posted: 11 November 2009 at 9:35pm
Originally posted by Saul Saul wrote:
Originally posted by decibel audio decibel audio wrote:
I WOULD GO VOID ALL THE WAY
yes, but there are other companies doing incredible sounding gear too y'know....
Very true and does anybody know who did the sound for the Jazz world stage and what system it was ?
it was an EV line array and APR audio are the guys
APR
Sound Hire
Post Options Post Options   Thanks (0) Thanks(0)   Quote bassmattmatty Quote  Post ReplyReply Direct Link To This Post Posted: 11 November 2009 at 9:37pm
Never thought about the time it takes to calculate angles. Good point
Post Options Post Options   Thanks (0) Thanks(0)   Quote bassmattmatty Quote  Post ReplyReply Direct Link To This Post Posted: 11 November 2009 at 9:39pm
LOL Silly me, thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote backlash Quote  Post ReplyReply Direct Link To This Post Posted: 11 November 2009 at 9:39pm
of course it would, I know absolutely nothing about line arrays, but what i know from point source is you need to get the right dispersion from the cabinets, and if done wrong, the sound is very uneven across the venue, and it can sound brilliant at the mix position but no where else. You need to make sure people at the back hear as well as the people at the front.
Sound Hire
Post Options Post Options   Thanks (0) Thanks(0)   Quote bassmattmatty Quote  Post ReplyReply Direct Link To This Post Posted: 11 November 2009 at 9:40pm
APR
That was the best system I’ve ever heard
tallmike View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tallmike Quote  Post ReplyReply Direct Link To This Post Posted: 11 November 2009 at 9:42pm
I'd like to see how long it takes for them to fly that AC/DC point source system compared to the equivalent linearray system. I'm guessing 3-4 times as much.
speaker monkey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote speaker monkey Quote  Post ReplyReply Direct Link To This Post Posted: 11 November 2009 at 9:42pm
Did it look nice too?
And God said "Let there be light" and there was light.
But for him to speak, sound must have come first.
Post Options Post Options   Thanks (0) Thanks(0)   Quote backlash Quote  Post ReplyReply Direct Link To This Post Posted: 11 November 2009 at 9:44pm
not as nice as void, BUT as I'm 6"4 the EV X array worked for me!
Sound Hire
Post Options Post Options   Thanks (0) Thanks(0)   Quote bassmattmatty Quote  Post ReplyReply Direct Link To This Post Posted: 11 November 2009 at 9:45pm
I’m fully aware that looks is not everything but I’m sure it helps
