hifi column bass speaker |
Post Reply | Page 12> |
snowflake
Posted: 11 January 2019 at 4:03pm |
Hi been wondering if this sort of speaker would work. It is a bipole (not a dipole) with the two drivers wired in phase. mounted either end of a tube which is placed vertically on a stand to allow ratiation from the bottom driver. the idea is that you get an increase in directivity in the horizontal plane and some cancellation upwards and downwards. should work over a couple of octaves before you get ridiculous comb-filtering rather than a doughnut-ring shape. idea is to increase direct over reverberant sound field so that it behaves more similarly to a dipole midrange than a monople woofer would. speakers are mounted opposite each other so shouldn't vibrate the cabinet and floor. I'm not sure whether it makes sense to divide the tube internally and/or to fill it with stuffing. could also set one or both drivers back from the end of the tube a bit to adjust rear volume and change the path lengths. very easy to buy a bit of sewage pipe and test this so will do so ASAP. I can't find any online reference to this sort of design - is that because it's mental? Phil
Finjby
Registered User Joined: 19 January 2016 Location: Shropshire Status: Offline Points: 74 |
Reminds me of the old Bose acoustic wave cannon idea. Remember one in a club in Broad street in Wolverhampton in the 90's with one slung above the bar... went low but not very loud.
Find some pipe and give it a go, should be good for home hifi volumes.
snowflake
thanks. the bose was over twice the length but kind of similar. the bose has one driver a quarter of the way down the tube so the two ends are in phase over about an octave. my idea should have similar radiation pattern but have wider bandwidth, lower efficiency, and less resonance.
snowflake
snowflake
this sim doesn't show any of the directivity effects. just seeing if it is realistic with tube volume and stuffing to get some decent output. can anyone point me to a better pipe than this? Edited by snowflake - 15 January 2019 at 10:20pm |
Pasi
Old Croc Joined: 25 April 2010 Location: Knutsford Status: Offline Points: 2732 |
Thanks(1)
200hz 300hz 400hz
snowflake
thanks for those. what does putting a floor in do? should be able to steer the lobes by having a longer length of tube in front of one driver.
snowflake
Thanks(1)
@Pasi, what software would you recommend for producing plots like those? I've always used Hornresp and Akabak to design my other projects but they aren't going to be much help on this one.
snowflake
also just remembered I can't get Akabak to run on a 32-bit emulator on this windows10 machine for some reason :( might have to dig the old PC out from under the bed.
sgarfa
Registered User Joined: 10 December 2013 Status: Offline Points: 101 |
i run akabak in VMlite xp mode ..on win10 without problems
snowflake
thanks, will try that. I tried using Oracle VM VirtualBox and got an error message "Raw-mode is unavailable courtesy of Hyper-V. (VERR_SUPDRV_NO_RAW_MODE_HYPER_V_ROOT)."
toastyghost
Thanks(1)
That’s just side view of EASE Focus with a generic source. It’s free, but it doesn’t do boundaries. You won’t get much of anything that does boundaries for sub-100Hz I’m afraid. |
