high UK mains voltage |
snowflake ![]() Old Croc ![]() Joined: 29 December 2004 Location: Bristol Status: Offline Points: 3005 |
![]() ![]() ![]() ![]() ![]() Posted: 06 February 2023 at 11:30am |
Hi
I live in Bristol and have always noticed that the mains voltage seems higher than where I have lived previously. I don't think I've ever seen it below 245V in my house. Venue where I work at is regularly exceeding 250V and seems to have increased gradually over last year..
It's supposed to be nominal 230V and in the range 216V to 253V. Some of my amps are specified to work on up to 260V which isn't very far above what we are getting out the mains. We have some distro equipment in the venue that has voltage protection alarm and cut out. Should I set these to protect the equipment or am I being paranoid about something that everyone else is living with without problem. Was thinking alarm at 253V and cut-out at 260V. cheers Phil |
kedwardsleisure ![]() Old Croc ![]() Joined: 20 January 2009 Location: Staffordshire Status: Offline Points: 4793 |
I would ask the DNO (Western Power?) to fit a datalogger to the premises in question, I assume they still do this sort of thing
North Staffordshire |
fatfreddiescat ![]() Young Croc ![]() ![]() Joined: 15 October 2010 Location: N.E.Wales Status: Offline Points: 1020 |
I had high voltage at home last year, spoke to SPenergy who fitted a data logger, showd a high of 257V so they knocked it down on the neighbourhood pole mounted transformer, I'm also at the far end of the line from the transformer! They did also check the other phases to make sure non were at the low end in case the phases were unbalanced.
As an aside, they initially suggested it could be solar panel feed in that was temporarily upping the voltage, at least they tried to fob me off with that until I pointed out that solar pv needed solar and that wasn't very plentiful at 2am. For solar pv to feed in to the grid, the grid voltage needs to be several volts below 253V which is the max the inverters will go to, so if high voltage on the line, solar pv can't add anything onto the grid, go figure...
APC321 ![]() Young Croc ![]() Joined: 24 August 2013 Location: West Midlands Status: Offline Points: 599 |
From the National Grid website:
In the UK, the declared voltage and tolerance for an electricity supply is 230 volts -6%, +10%. This gives an allowed voltage range of 216.2 volts to 253.0 volts. |
teeth ![]() Registered User ![]() Joined: 05 July 2021 Status: Offline Points: 330 |
i don't really have anything meaningful to add, but i would say that more protection is almost never a bad thing :)
djeddie ![]() Old Croc ![]() ![]() Joined: 26 April 2004 Location: Bristol Status: Offline Points: 4119 |
FWIW, I'm in East Bristol, (well, South Glos actually), and I've pretty much always had 243 - 250 Volts.
