Higher voltage? |
Post Reply | Page <12 |
studio45
Right on - actually that is ringing a faint bell for me too. When I typed the post I was looking at a 36v wheelchair battery charger that has a 4 pin male XLR output wired + on 1 and - on 3. Do you recall the standard pinout/gendering for camera gear?
slaz
Definitely don't remember the pinout - but Mr. Google reckons it seems to be fairly standardized at pin 1 = ground pin 2 = n/c pin 3 = n/c pin4 = +12V Thinking about it - reminded me of the time I was making up a "special" camera cable .... a 26-pin umbilical for some reason. Hours of effing and blinding later an awful truth descended - I'd managed to solder all the reqd. pins (bear in mind this was with very inadequate tools/facilities) ... but had forgotten to slide the 26-pin connector's outer shroud over the cable :-) :-) ISTR that was the night I rocked up back home at about 2 a.m. and got a grilling from the missus who thought I was having an affair :-) |
imageoven
Old Croc Joined: 28 March 2007 Location: Scotland Status: Offline Points: 2186 |
There should be a specific word for this I recently replaced a 19 pin socapex connector and only after tightening the back nut noticed that there was a second back shell and nut still threaded on the cable.🤔 Easier to hacksaw an aluminium backshell off than resoldering 26 pins. But I imagine I went through the similar emotions.
studio45
What do we reckon is a good connector for >12v DC then? Because, in fairness, a 4 pin XLR isn't rated for much current either; OK for a charging socket though.
My first thought would be to use 3-wide Anderson PP30's: if you use a red, a green and a black, clipped together in that order, and only connect wires to the red and the black, then you have a polarised connector that can't be plugged into any normal 2-wide configuration and actually make the circuit. You could even use the green shell for a temperature sense line or similar. Of course you could split a 2-wide apart and make the connections, but at that point you either already know what you're doing or are about to learn *real* fast :)
APW
the White -h8 ceeform is rated up to 250Vdc, the -h3 variant (Also White) can be used for 50 to 200Vdc
http://www.farnell.com/datasheets/1514435.pdf - page 93. |
csg
Amphenol C0 16 series are ideal for this, small, tough, weatherproof, inexpensive and reliable. Used them many times on custom power supply or lamp ballast applications.
SteveAATW
Young Croc Joined: 04 September 2007 Status: Offline Points: 1173 |
Kipman - out of interest have you built a BMS into the system?
Digbethdave
Registered User Joined: 16 November 2018 Status: Offline Points: 406 |
I've seen someone forget the nut, to tighten a basket weeve on tl37. He pinned it up, tested it, then tried putting it together....
SamV
Old Croc Joined: 21 October 2008 Location: London Status: Offline Points: 8711 |
I'm curious why you've built such a high voltage pack only to go use a DCDC to knock it to about half? Or was the plan to always find something suitable at a later date? I would have thought two 36v packs would be better. So in an extended use case, one could be taken and charged while the other worked?
kipman725
Registered User Joined: 02 September 2020 Location: Warrington Status: Offline Points: 231 |
Yes there is a bluetooth 50A BMS in the ammo can, if i put my phone close to it I can read it out. yes its a bit stupid knocking the battery voltage down to 36V. I built the pack as a nominal 64V pack as this would give ~500W into a 4 ohm load from a full bridge amplifier if that was the amplifiers DC bus, I then found out that there aren't any single supply off the shelf amps apart from very expensive Sure ones that can run off this bus voltage and the Sure ones have high idle currents. I couldn't even get the higher voltage TPA3255 at the time I built it during the start of UK lockdown so ended up with the buck converter as a bit of a bodge. I am however working on a new amp that will not need the buck converter and be very cheap based on the IR4301 running full bridge with alucore board to get the heat out. |
