highest rated 12" drivers for midrange |
Page <1234 8> |
| Author | |||
heinrich
Joined: 21 February 2007 Location: Calindagan Status: Offline Points: 280 |
Posted: 12 February 2009 at 1:53am |
does voice coil diameter affects?
3" compared to a 4" more or less same EBP's ? any insights please....... |
.....power is nothing without control....
streetsounds
Joined: 12 July 2008 Location: Santa Rita Status: Offline Points: 301 |
Posted: 13 February 2009 at 1:12pm |
P Audio C12 500MB, pretty good with MT 122 design cab ![]() Edited by streetsounds - 13 February 2009 at 1:13pm |
Bass matters...
Teunos
Joined: 23 November 2008 Location: The Netherlands Status: Offline Points: 1832 |
Posted: 13 February 2009 at 6:36pm |
Please don't use them. they sound rubbish in lower mids and with disortion. not a proper lower mid speaker. It sounds funny, but it's better for lows. |
Best regards,
Teun. |
Mircea Bartic
Joined: 18 February 2005 Location: Romania Status: Offline Points: 2589 |
Posted: 13 February 2009 at 8:17pm |
I did mounted on a F12CVH from dynacord, made massive amounts of SPL |
Mircea Bartic
Posted: 13 February 2009 at 8:19pm |
should work very well in MT122, as it's very similar to the F12CVH
heinrich
Posted: 14 February 2009 at 8:59am |
yup.......as per specs it has an EBP that qualifies for mids....... #1 on my list ......... I am also wondering if Peavey's 1201-8 black widow series will also be worth trying since it also has an EBP higher..... and has a 4" voice coil......... streetsounds, how much is the P audio C12 500mb in your place Edited by heinrich - 14 February 2009 at 9:00am |
streetsounds
Posted: 14 February 2009 at 9:22am |
Pards eto na gamitin mo. This is what I used in my midhi cab with PADE99 driver in the center, pretty similar to MT 122 (the one on the pic), very clean and crisp. Its driven by Labonn 1300w rms per channel, walang ubos pards. 1:4 ang ratio nya sa sub.
P5,900 ang presyo nya dito sa Manila
Bass matters...
Mircea Bartic
Posted: 14 February 2009 at 10:36am |
Heinrich
Be advised that C12-500 is no longer in Production at P-audio.. |
streetsounds
Posted: 14 February 2009 at 11:28pm |
@Heinrich
You can use the new C-12MB then, if thats the case:
The new P-Audio C-12MB Challenger Series II 12" 600w mid bass speaker
The C-12MB has been designed specifically for use as a mid bass transducer. This 12 inch (315mm) diameter driver has been optimized for use as either a direct radiator mid bass driver or for use in a horn loaded mid bass design. The Challenger series II C-12MB is optimized for a combination of low frequency response and efficiency. The C-12MB has been designed for maximum efficiency thru the operating range of 60Hz to 2000Hz.The frequency range of 120Hz to 2000Hz is the critical mid band range where vocal fundamentals as well as fundamentals of most musical instruments are found.This area is critical to system clarity and intelligibility and the C-12MB, with its newly developed highly damped cone material, is optimized. ![]() The large format 4 inch (101.6mm) voice coil diameter produces a large cross sectional area for maximum heat transfer and power compression. The rectangular geometry voice coil provided a professional level of power handling and critical reliability. Like all models in the Challenger Series II, the C-12MB features a large diameter Ferrite based permanent magnet coupled to an aluminum die cast chassis. Because of its very high efficiency design, the C-12MB is designed for mid bass applications only. For system designs where additional bass is required the C-12MB is a superior choice. |
Bass matters...
heinrich
Posted: 15 February 2009 at 1:56am |
my bad |
heinrich
Posted: 15 February 2009 at 1:59am |
street did you mention PADE99 ? where can I buy this.in manila ? magkano kaya? Edited by heinrich - 15 February 2009 at 2:02am |
streetsounds
Posted: 15 February 2009 at 10:38am |
It was 10,440 pesos the last time i bought it, sa Music Box. Pumupunta ka ba ng manila
Yung bago na C12 MB e 7200 SRP
Bass matters...
Page <1234 8> |
