Hiring early '70s cabs for photoshoot |
Post Reply | Page <1 234 |
chvintage
New Member Joined: 12 February 2019 Location: cheshire Status: Offline Points: 6 |
Quite a lot of the stuff works- if it is needed for a job where it needs to work it usually can be serviced to do so
jbl_man
Was looking at the video only the other day Chris...what are the sectorial multi-cell horns used there? Vitavox? Altec? You get a glimpse of the horns drivers hanging out the back of the cabinets on the rear shots on the video, JBL? Altec? I assume the bass drivers in the cabinets would also be something much more substanial than the usual WEM fitment....Celestion Powercel maybe? The WEM system was clearly inadequate for Pink Floyd's needs,as just a year or so later they were using a huge Martin system shown below based around the 215mk1. This is 1973. Edited by jbl_man - 13 February 2019 at 11:04am |
Robbo
Old Croc Joined: 05 December 2005 Location: Shropshire Status: Offline Points: 4226 |
Ian---The pic above shows cabinets that were used by the London based hire company TASCO back in those days---All of the 2x15 Martin Audio bins were built by or for TASCO and are not original Martin Audio boxes.
I bought a load of them from Joe Brown at TASCO when they were up for replacement and Slade ended up with 16 of them as well to replace their old Charlie Watkins designed 2x15 curved front cabinets. The 2x15s were loaded with Gauss drivers(5831 I think if my memory serves me correctly) and it looks like all of the Radial horn boxes were TASCO cabinets as well--JBL 2" 2482 and 2440 loaded. |
madboffin
Old Croc Joined: 03 July 2009 Location: Milton Keynes Status: Offline Points: 1539 |
I don't have a definite answer, but Marley was a long-term client of TFA Electrosound. They had a large system based in the UK and would likely have been the first choice when that show was arranged at short notice. Edited by madboffin - 13 February 2019 at 3:42pm |
madboffin
I always thought the WEM multicells were the small Vitavoxes (Type 550).
Any idea what drivers were fitted, possibly Vitavox GP1's? |
Robbo
Yes Vitavox GP1 drivers were fitted on the very first Festival Stacks but were changed to RCF horns and drivers in the later ones.
I think I mentioned above that I owned two pairs of Festival stacks back in the day and they were mismatched--we updated HF drivers and horns etc when refurbing the earlier pair at one point due to original cloth with lined pattern on it going all baggy and horrible and fitted the newer cloth that was almost black with sparkly bits in it. At the same time we changed all 10" 12" and 15" cone drivers to JBL and Gauss in all four stacks so were then completely matched and also sounded so much better than the original Celestion cones. |
jbl_man
The Pompeii video...you can see the drivers poking out the horn cabinets backs at around 6.25 mins.
Robbo
Yes--GP1 drivers, can tell from the size more than anything as they were very small compared to the later and much larger S3 unit.
The twin sectoral cabinets with gold coloured horns are the early Festival Stack HF cabinets and having to watch that video has just reminded me of how boring I found Pink Floyd back then and still to this day---I have probably just offended half the forum members with that but sorry guys. |
csg
Just dug out the dvd of Pompei. Definitely a couple of the larger vitavox 220hz horns there too alongside the smaller , gold 550hz units. I should imagine that they would have been driven by S2’s or S3’s.
godathunder
Old Croc Joined: 19 July 2004 Location: wicklow Status: Offline Points: 1834 |
Im pretty sure the 2 larger wem cabs behind gilmour are the 1x18s
burke from budgie used to hang a pair of them off a marshall major run pretty much flat out, even for smallish pub gigs it was quite visceral |
LOUDER THAN LOUD
chvintage
The horns at Pompeii were Vitavox sectoral 6 cell twins x 2 and 15 cell vitavox sectoral x 1 the dtivers in the single festival stack per side plus all the columns were fairly standard goodmans and celestions
chvintage
the two larger cabs per side next to each set of WEM Starfinder 4 x 12s are ported infinite baffle 2 x15s
for Roger's bass I have four of them
