  New Posts New Posts RSS Feed - Hiss from driver
Hiss from driver
LjudLahger View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LjudLahger Quote  Post ReplyReply Direct Link To This Post Topic: Hiss from driver
    Posted: 18 October 2022 at 9:05pm
Hi
When I do some listening and tweaking in my living room, I can hear a hiss from my driver clearly. I would like to be able to listen to music like a hifi. My solution has been a 33ohm resistor to get it down but I would like to know if there is anything I could do, in my amp to get it down.
The driver is a B&C DE500 on a XT1086 horn and amp Amtech ASPL 6x100 an oldschool passive amp 6ch like new. Perfect for my diy living room rack.
I have read in a few threads here that if this accurse just turn down the levelnobs on the amp, but this amp does not have any…and the other amps mentioned was class D if that matters?
Is this true?
I would really like to use this amp but is it old technology and I need a better one with higher s/n ratio?
Many thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote LjudLahger Quote  Post ReplyReply Direct Link To This Post Posted: 18 October 2022 at 9:13pm
The amp
Post Options Post Options   Thanks (0) Thanks(0)   Quote Elliot Thompson Quote  Post ReplyReply Direct Link To This Post Posted: 18 October 2022 at 9:18pm
You can use a potentiometer as it is a variable resistor. Very common in Hi-Fi passive crossovers to dampen the high frequencies.
Best Regards,
full speed View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote full speed Quote  Post ReplyReply Direct Link To This Post Posted: 19 October 2022 at 3:20am
you can t do nothing about that is the design of the amp and is common problem with compresion drivers that is very sensitive.the only way is to change the amp with quiter one or change the gain structure of your system (controler mixer).my systems have all so a little hiss in a room heard from 3-4 meters 111db-1m drivers but outside who cares.to be sure is the amplifier just disconect the input cables live speakers conected and turn the pots at full position.if hiss stil there is the amp.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MarjanM Quote  Post ReplyReply Direct Link To This Post Posted: 19 October 2022 at 1:33pm
Turn the amp down like half way.
BJtheDJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BJtheDJ Quote  Post ReplyReply Direct Link To This Post Posted: 19 October 2022 at 5:12pm
OP said "just turn down the levelnobs on the amp, but this amp does not have any…"
If your vaccinations were mandatory and nobody in your class had measles,
then you know that you're not a Millenial kid.
</f
kipman725 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kipman725 Quote  Post ReplyReply Direct Link To This Post Posted: 19 October 2022 at 6:11pm
if the amp still hisses with a shorted input there is nothing you can do (the amp is generating the noise) apart from padding down the comp or getting a higher SNR amp (or lower power with the same SNR).
If the hiss is reduced when the input is shorted then an inline attenuator will improve SNR.  Your crossovers maximum linear output and the input sensitivity spec of the amplifier give you the optimal attenuation if you wish to retain full output capability.  EG. at home I use 14dB attenuators as my DSP can output +14dB more than my amps need to clip.  Without the attenuators I also hear hiss.
Post Options Post Options   Thanks (0) Thanks(0)   Quote LjudLahger Quote  Post ReplyReply Direct Link To This Post Posted: 19 October 2022 at 6:53pm
Thank you all for your input.
I will try shortening inputs to driver channel and a/b listen. If still hiss I know its the amp.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Elliot Thompson Quote  Post ReplyReply Direct Link To This Post Posted: 20 October 2022 at 2:19am
Best Regards,
Simply put. The Compression Driver is picking up the noise floor of the amplifier. This is a common trait when using highly sensitive compression drivers in your home. This is why, many will reduce the sensitivity of the driver with a resistor or potentiometer. That is the benefit of a passive crossover.
Best Regards,
