  New Posts New Posts RSS Feed - hog scoop bild questions
Dan12345 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan12345 Quote  Post ReplyReply Direct Link To This Post Topic: hog scoop bild questions
    Posted: 12 September 2017 at 11:36am
Hi I have some questions about billing hog scoops
Q-1 What size screws should be used wen bilding
Hogs ?
Q-2 what is the best glue to use pvc wood glue or polyurethane wood glue ?
Thanks in advance
SouthwestCNC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SouthwestCNC Quote  Post ReplyReply Direct Link To This Post Posted: 12 September 2017 at 11:59am
Hhahaha. 4 x 40mm but good luck getting a straight answer about the glue. Personally I think PU. Contrary to lots of tests results found on the net, ive compared with titebond 2 with ply and PU is a considerably stronger joint providing the joint has sufficient clamping force and is not dry.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SouthwestCNC Quote  Post ReplyReply Direct Link To This Post Posted: 12 September 2017 at 12:06pm
All that said there are many grades of PU, some are not as good as others. My test were using soudal purcol express.
KingGwarn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KingGwarn Quote  Post ReplyReply Direct Link To This Post Posted: 13 September 2017 at 7:42pm
+1 to the pu glue ... and +1 to southwestcnc for recommending it to me in the first place!
I much prefer it as can get it in a tube for a caulk gun which makes things less messy....just don't get it on your clothes or anything as that shit doesn't come out!
Soundman inna Brighton town
King Gwarn Sound System
