Hog Scoop Driver |
Post Reply | Page <1 34567 8> |
MarjanM
That is because most of them have never actually seen or heard them.
renzelkouten
Registered User Joined: 21 August 2006 Status: Offline Points: 288 |
Are there any lower rated drivers that will work well in the Hog design?
Something along the lines of the PD186, Oberton 18XB800 ? |
dub it up
turbo7
Registered User Joined: 15 March 2009 Status: Offline Points: 233 |
BMS 18S450 is a great driver for scoops. It has 12mm "real" xmax and sounds very warm
bass*en*mass
if someone could do with 4 of these terrible drivers gimme a shout :)
turbo7
I have just got a pic with broken driver. Too less glue on inner spider-cone part. Broke after 5 times of use...
edit: it is the only one which ever had a fault until now. Several out there without problems. Edited by turbo7 - 16 September 2015 at 8:47pm |
AlmostSalty
Registered User Joined: 06 June 2011 Status: Offline Points: 415 |
PD1850 over void, i've done a a-b test on void and pd, and a turbomax too. The PD sounded more musically and also as if it plays a bit lower than the void. I don't think you would be disappointed with the void tho. As for the turbomax in a hog, doesn't work.. Sounds like its playing outside the room, sounds hollow!
Now, I'm trying to sim the hog scoop for something else but im having a hard time getting the driver to sit at the throat of the horn: Anyone know what i'm doing wrong? edit: image Edited by AlmostSalty - 19 September 2015 at 8:31pm |
PinHole
Registered User Joined: 14 September 2013 Location: behind you Status: Offline Points: 93 |
You have set way too small "Atc" so rear chamber is shown like duct. Edited by PinHole - 20 September 2015 at 7:50pm |
Signature is important. So I always write something in this dedicated field.
AlmostSalty
Do you know what atc should be set as for the hog scoop? The same as Sd? I'v been using the input parameters from this link: https://www.freespeakerplans.com/forum/38-hosted-plans/5466-hog-scoop#13970
all bass
I would start by not making it a TH...
AlmostSalty
all bass
Simulate it as a normal rear loaded horn(scoop).
Have you compared your inputs with the ones that can be found on google? They differ in a lot of ways.
AlmostSalty
I did not, was looking ones on here, and found this:
http://forum.speakerplans.com/scoop-hr-input-reference-guide_topic89839.html and another post with an SP member linking to the one on FSP. They are the same so i thought there was a good chance it was accurate! Thanks for the link |
