HOG Scoop |
Page <1 23456 63> |
Mircea Bartic ![]() Old Croc ![]() ![]() Joined: 18 February 2005 Location: Romania Status: Offline Points: 2581 |
hehe
it's getting warm outside It smells like hog scoop testing to me ![]() I'll give it a go as soon as I'll return from Musikmesse |
jethrocker ![]() Old Croc ![]() Joined: 07 June 2006 Location: Chiapas, Mexico Status: Offline Points: 1942 |
madboy..that cicuit will do the job fine.. though I'd recommend working out the highpass frequency you require for your bins and building it with fixed resistors rather than the twin pot.
This will have a couple of advantages, the first being that no-one can accidently change the setting either robbing you of low end or giving your bins frequencies they don't want. The second is that matching of the two resistors is essential, and matching between the sections on twin pots is always a bit of a problem, even expensive ones.
If you build with fixed resistors, measure from a selection to get an exact match.
Another thing to consider..where are you going to put this circuit in your signal chain? Worth putting it in as early as possible, between source and preamp stages if possible, just to gain a bit of headroom through the chain.
Hey Champ.. the chamber issue in scoop designs has been discussed a fair bit, and seems to divide the troops, particularly the roots sound boys who often favour a bigger chamber.
I think that a smaller chamber will give a smoother response higher up, and a generally tighter more musical sound. These designs are more suited to drivers with parameters suitable for front horn loading such as 1850s.
Scoops with large rear chambers (to me) sound a bit lower, but less defined and more "flappy" and seem to lack tone higher up.
The angled baffle should be fairly obvious.. It makes the baffle part of the final flare extension, giving a larger mouth area and therefore lower cut off for the same size cab.
CHAMPION ![]() Old Croc ![]() Joined: 30 September 2004 Location: United Kingdom Status: Offline Points: 3660 |
Cheers, so theese Hogs should give a more tight smoother sound.
And other Super / ASS scoop should give a more lazy low slow bass.
I suspose it also depends on what type of music you play, hence you boys know.
So what would these Hogs be compared to a 186 / 1850 Horn ??
Sticks n Stones
Don't think you can compare them to a 186/1850..they're still a scoop or rear loaded horn design with a direct radiating element-rather than a front loaded horn.
There has been some discussion, without any real conclusions, on how this concept could relate to the tapped horn principle.
It's always pretty hard to compare cabs anyway, they all tend to have their individual pros cons and peculiarities.
The Hog is a scoop, just reworked, looks like it will drop lower, and staipers testing supports this. Haven't heard one though so I'm not going to compare it to anything... If I can get my hands on a suitable driver or two I'm going to be very tempted to give them a try though!
Edit:Horrific spelling on account of worn webcafe keyboard with no letters left on keys/mad rush to get to work.. Edited by jethrocker - 14 March 2007 at 6:14pm |
mykey ![]() Old Croc ![]() Joined: 18 August 2005 Location: UK/Indonesia Status: Offline Points: 9680 |
if you think the Hog chamber is small, you should see the DubSub chamber
![]() @Jethrocker
your bang on mate ![]() Edited by mykey - 14 March 2007 at 10:55am |
TONY.A.S.S. ![]() Old Croc ![]() Joined: 21 February 2007 Location: United Kingdom Status: Offline Points: 6878 |
What's all this about slow and lazy? these cabs are installed in some heavy dance clubs.So they can be hard and tight. But as always- signal dependent. |
Tekasis ![]() Old Croc ![]() Joined: 03 July 2006 Status: Offline Points: 6492 |
Are you saying the DubSubs chamber is even smaller Mykey ?
madboy ![]() Registered User ![]() Joined: 06 January 2007 Status: Offline Points: 27 |
hei boys give here frequency responce of this cabs. HOG scoop
dubsub scoop
and how it is sound with black hip-hop , techno and many more music with
more bass?
R U sure mate ??
gazman ![]() Registered User ![]() Joined: 30 January 2006 Status: Offline Points: 100 |
...black hip hop?! LOL!
I don't think anyones done any proper measurements yet madboy these things are fairly new.
Page <1 23456 63> |
