  New Posts New Posts RSS Feed - HOG Scoop
HOG Scoop
 Post Reply Post Reply Page  <1 4950515253 63>
Audio-kid View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Audio-kid Quote  Post ReplyReply Direct Link To This Post Posted: 14 October 2013 at 8:45pm
are these images im drooling over staipers re- hog design in the purple and black and also blue ones. im wanting to make my very first ever scoops so im after the plans and cut lists.
cant afford to buy custom build due to being undercut on the hire side these days soooooo want to try building my own.  thought id go for 4 x.
should be deep and loud enough lol.
Sypa View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Sypa Quote  Post ReplyReply Direct Link To This Post Posted: 15 October 2013 at 2:02am
Originally posted by JR.junior JR.junior wrote:
If you need PD1850, I can sell you two.
No,but thanks anyway.Dont use PD although in the future plan to. Is there/are you a distributer for pd in dežela?
jngggggggg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jngggggggg Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2017 at 10:41pm
fellow hoggers!!
i am considering building 4 hogs to use as subs for a 3 way system (subs, kicks, 2way mid/top).
are hogs capable of producing below 30hz with high spl when loaded w an ideal driver? tnx!
Sypa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sypa Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2017 at 1:38am
In a stack of six they can play 30hz without problems i would say, on the spl in theory they are flat to 30 with six.
Sypa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sypa Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2017 at 1:40am
Didnt see u want below 30 . First of all are you sure u need that ? I think the driver unloads below 25ish hz .
bass*en*mass View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bass*en*mass Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2017 at 7:02am
if you really need to go below 30hz -3db you might want to take a look at the othorns..
expensive driver, large`ish cab+needs proper power but should do the job ;)
Hogs wont do much with authority below 35ish in stacks of 4?
in stacks of 6 30hz -6ish db but def. not happy much lower due to horn path/unloading?
bzhm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bzhm Quote  Post ReplyReply Direct Link To This Post Posted: 03 July 2017 at 10:16am
Hi,
Does anybody know which speaker is used by Imperial Sound Army in their hogs ?
Thanks,
Matt276 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt276 Quote  Post ReplyReply Direct Link To This Post Posted: 03 July 2017 at 12:03pm
It  looks like Turbomax
paulus View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote paulus Quote  Post ReplyReply Direct Link To This Post Posted: 03 July 2017 at 12:13pm
was tmax with green surround know i believe they are on turbomax red eyes
TRENDSETTER SOUND SYSTEM
bzhm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bzhm Quote  Post ReplyReply Direct Link To This Post Posted: 03 July 2017 at 2:46pm
Hi,
yes previously tmax with the green circle but now all black...
Do you think it s this one now?
http://rmjloudspeakers.com/acatalog/info_210.html
RMJ Red I 1500 18"
MODEL Red I 1500
Fs 35.4286
thx
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt276 Quote  Post ReplyReply Direct Link To This Post Posted: 04 July 2017 at 3:33pm
or maybe :
RCF LF18X401
bzhm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bzhm Quote  Post ReplyReply Direct Link To This Post Posted: 05 July 2017 at 2:21pm
ok thanks, another possibility !
I that can help i think it s driven by ffa10k...
