  New Posts New Posts RSS Feed - HOG Scoop
HOG Scoop
 Post Reply Post Reply Page  <1 5455565758 63>
Tonskulus View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tonskulus Quote  Post ReplyReply Direct Link To This Post Posted: 27 August 2018 at 10:49am
Originally posted by BBHF BBHF wrote:
Anyone using the 18NLW9601 in Hogs? Enough chamber?
Well I'm thinking HOG as small chamber scoop. NLW9601 should be really good driver for HOG.
Actually I'm a bit confused about chamber size vs. driver VAS.. what is the difference there high vas vs. low vas drivers in reality? (same thing with tapped horns without chamber).
My hogs are loaded with RCF LF18X400's atm and they do their job (vas: 340 litres!). Not sure, maybe there something is missing (losing some control?) but still they are quite loud and nice sounding. For sure some 18v1000, pd1850 etc would be more brutal and controlled..
Just wondering what would be the difference if I change to lower vas drivers.. or something.  Anyway I have a feeling that HOG likes lowish vas drivers.. is this correct?
Edited by Tonskulus - 27 August 2018 at 11:38am
Jhodas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jhodas Quote  Post ReplyReply Direct Link To This Post Posted: 28 August 2018 at 10:00pm
Saw a quartet of these beauties at Leeds carnival throwing some serious air around!
Outdoors and no corner loading, with that nice scoopy nuttiness.
Unfortunately, I can't remember the name of the sound, so any help there would be great.
Also, forgive the appalling sound quality, phone could not hack it.
Tune is Lord's Prayer by Prince Jamo.
premo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote premo Quote  Post ReplyReply Direct Link To This Post Posted: 29 August 2018 at 2:59am
Bit off topic but has anyone tried end-firing with hog scoops?
I have a gig coming up in a few mouths and the client has asked if we can reduce the bass pressure behind the stage for camping ect.
Also am i correct in thinking that a hog is a tapped horn not a rear loaded horn (scoop)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tonskulus Quote  Post ReplyReply Direct Link To This Post Posted: 29 August 2018 at 5:54am
Well for me it looks like a hybrid of both. Tapped horns as far as I know, has no back chamber at all..HOG do have back chamber but its quite small.  Don't know how well end-firing works with horns, but it should work.  Even two hogs togerher really has some directivity or "throw" tho, when I was walking around my hog stack. There was MUCH more bass at front of hogs than behind even 5 meters away.  But yes, there is a lot of bass behind them too so end-firing might be the trick there.
Oh well my friends were so scared when I turned up the volume while they were standing in front of two Hogs.  No wonder, it was hard to breath and vision was blurred at 1 meter.. propably around 135-140dB of bass.
bozhidar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bozhidar Quote  Post ReplyReply Direct Link To This Post Posted: 30 August 2018 at 8:59pm
Zulu Swarm Soundsystem outta Leeds
https://www.facebook.com/profile.php?id=100009762096551
Edited by bozhidar - 30 August 2018 at 9:00pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jhodas Quote  Post ReplyReply Direct Link To This Post Posted: 30 August 2018 at 10:12pm
Yes! Bless, thanks.
Edited by Jhodas - 30 August 2018 at 10:15pm
Arcy12 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Arcy12 Quote  Post ReplyReply Direct Link To This Post Posted: 29 September 2018 at 8:20am
What are everyone's thoughts on a V18-1000 verses the 18PW1400Fe 8 ohms in the hog scoop? Has anybody heard both? Thanks
unclejam View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote unclejam Quote  Post ReplyReply Direct Link To This Post Posted: 01 February 2019 at 2:43am
Does anyone have the Cad Plans for the Hogs? 4x8 ply
fatfreddiescat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fatfreddiescat Quote  Post ReplyReply Direct Link To This Post Posted: 01 February 2019 at 8:56am
End firing cardiod/supercardiod should work just fine especially as they are relatively narrow band sub by design, it being a hog as opposed to a reflex covering the same band should not matter one bit as to do with relative phase between the cabinets, so as long as all the cabs share the same phase response then not a problem.
djhrh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote djhrh Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2019 at 12:11am
Did you find the plans mate? Would love if you could send it over. Cheers
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tonskulus Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2019 at 11:19am
Hog scoop does have effective, exponential horn for bass reinforcement while typical tapped horn hasn't.  So for me HOG is a back loaded horn, at least more so than tapped horns.
Stacking two or more makes it even more effective as mouth area increases.
Great bass horn it is. I wonder if anyone here has measured its maximum continuous SPL @ 1m (half space environment) with a good driver beetween 30-70Hz?
Edited by Tonskulus - 09 May 2019 at 11:22am
sushi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sushi Quote  Post ReplyReply Direct Link To This Post Posted: 21 December 2019 at 9:35pm
Hi there! Have anyone tried the hog scoop with RCF LW18X401?
i would like to build 4 hogs and i'm looking for a good and deep low end woofer
