HOG Scoop |
Post Reply | Page <1234 63> |
madboy
Registered User Joined: 06 January 2007 Status: Offline Points: 27 |
ok i need choice a right driver for this plan pd1850void v18-1000
for more spl at 33Hz ~ 100Hz :)
Alex_C
Registered User Joined: 13 April 2006 Location: Leeds Status: Offline Points: 180 |
Hey staiper, i know this is off-topic but your PM inbox is full and i didn't want to start a new thread. I was just looking through the pics on your msn group and
found the plan for the m112, I'm currently about to build a pair
of 12+1 mid-tops and was just checking that it's ok to use these plans
as this seem to be just what I'm looking for (good cab but fairly easy
to build as my woodworking skills aren't all that great).
thanks, Alex p.s if i can use them i'll post a full set of build pics for them. Edited by supasniper - 04 March 2007 at 4:01pm |
Mircea Bartic
Old Croc Joined: 18 February 2005 Location: Romania Status: Offline Points: 2581 |
Marjan the only way I see it is that you will have to build a prototipe to find that out all my attempts to model this contraption have failed, and after I heared Rog say that he can't model it right either, I gave up completely. in my mind I know it should work but can not proove in any way without a measured response |
staiper
Registered User Joined: 26 February 2004 Location: Croatia Status: Offline Points: 545 |
Hello, L18P300 .. in sim. seems that would work very well. Booth PD1850 and V18-1200 are suitable for this cabinet. PD1850 will give a bit more aggressive "dryer" sound than other two noted in post .. all sim. prediction. @ supasniper ..Freely use those plans (M112). Even there all angles are 90 or 45 degrees it is good to cut it on good saw table .. 45 degree angles cut by hand-circular saw tend to be not perfect which greatly complicates further assembling. ….in hurry bye Stipe |
Tekasis
Old Croc Joined: 03 July 2006 Status: Offline Points: 6492 |
What about the V18-1000 ? as the V18-1200 seems to be not available in UK.
staiper
Hi,
V18-1000 is very close to PD1850. Will fit (even grooves on panels "J" & "B" are not required if panels and speaker cutout is positioned precse as required) ..but you will lose some LF extencion (under35Hz) in comparison with V18-1200 or L18P300.
Best wishes,
Stipe
madboy
tell us how much weight one box HOG Scoop ? pd1850 = 22 kg.
i dont know weight two flastness 18mm ply (13 laminate)
1220 mm. x 2440 mm. how much weight.? Edited by madboy - 05 March 2007 at 3:01pm |
jethrocker
Old Croc Joined: 07 June 2006 Location: Chiapas, Mexico Status: Offline Points: 1942 |
Someone posted the average weight of various thicknesses of ply the other day..don't know where though. Search it up and you'll be able to work it out..
Mircea Bartic
I would appreciate somewhere in the neighborhood of 120-140Kg / unit
staiper
.. 95-100kg with PD1850 in cabinet
Edited by staiper - 05 March 2007 at 6:30pm |
SmokeyJoe
Young Croc Joined: 22 August 2006 Location: United Kingdom Status: Offline Points: 534 |
I'm lovin' that design staiper! Its the best i've seen on this forum in a long time!
I'll probably build a pair for fun in the summer, do some outdoor parties with them...can you smell that barbecue... And i'll have a spare pair of PD186's to load them with, hmmm, this is gonna be fun! - Joe. |
madboy
and little bit from me:)
for this cabinet i must use HPF tuned about 26 ~ 33 Hz or NOT?
