  New Posts New Posts RSS Feed - HOG Scoop
HOG Scoop
 Post Reply Post Reply Page  <1234 63>
madboy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote madboy Quote  Post ReplyReply Direct Link To This Post Posted: 04 March 2007 at 2:45am
ok i need choice a right driver for this plan
pd1850
void v18-1000
for more spl at 33Hz ~  100Hz :)
Alex_C View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alex_C Quote  Post ReplyReply Direct Link To This Post Posted: 04 March 2007 at 4:00pm
Hey staiper, i know this is off-topic but your PM inbox is full and i didn't want to start a new thread. I was just looking through the pics on your msn group and found the plan for the m112, I'm currently about to build a pair of 12+1 mid-tops and was just checking that it's ok to use these plans as this seem to be just what I'm looking for (good cab but fairly easy to build as my woodworking skills aren't all that great).
thanks, Alex
p.s if i can use them i'll post a full set of build pics for them.
Edited by supasniper - 04 March 2007 at 4:01pm
Mircea Bartic View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mircea Bartic Quote  Post ReplyReply Direct Link To This Post Posted: 04 March 2007 at 5:16pm
Ok.. i will ask again.
Will RCF 18P300 work in this box?
Hornresp calulations are giving weird resulrs for any driver so i can figure it out.
Hvala za dizajn Stipe.
Regards
Marjan
Marjan
the only way I see it is that you will have to build a prototipe to find that out
all my attempts to model this contraption have failed, and after I heared Rog say that he can't model it right either, I gave up completely.
in my mind I know it should work but can not proove in any way without a measured response
Ex Nexus_3
staiper View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote staiper Quote  Post ReplyReply Direct Link To This Post Posted: 04 March 2007 at 5:35pm
Hello,
L18P300 .. in sim. seems that would work very well.
Booth PD1850 and V18-1200 are suitable for this cabinet.
PD1850 will give a bit more aggressive "dryer" sound than other two noted in post .. all sim. prediction.
 As Mircea says ; in my mind I know it should work but can not proove in any way without a measured response ;)
@ supasniper  ..Freely use those plans (M112). Even there all angles are 90 or 45 degrees it is good to cut it on good saw table .. 45 degree angles cut by hand-circular saw tend to be not perfect which greatly complicates further assembling.
….in hurry bye
Stipe
Tekasis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tekasis Quote  Post ReplyReply Direct Link To This Post Posted: 05 March 2007 at 2:49am
What about the V18-1000 ? as the V18-1200 seems to be not available in UK.
Post Options Post Options   Thanks (0) Thanks(0)   Quote staiper Quote  Post ReplyReply Direct Link To This Post Posted: 05 March 2007 at 6:59am
Hi,
V18-1000 is very close to PD1850. Will fit (even grooves on panels "J" & "B" are not required if panels and speaker cutout is positioned precse as required) ..but you will lose some LF extencion (under35Hz) in comparison with V18-1200 or L18P300.
Best wishes,
            Stipe
Post Options Post Options   Thanks (0) Thanks(0)   Quote madboy Quote  Post ReplyReply Direct Link To This Post Posted: 05 March 2007 at 2:41pm
tell us how much weight  one box HOG Scoop ?
pd1850 = 22 kg.
i dont know weight  two flastness  18mm ply (13 laminate)
1220 mm.  x  2440 mm. how much weight.?
Edited by madboy - 05 March 2007 at 3:01pm
jethrocker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jethrocker Quote  Post ReplyReply Direct Link To This Post Posted: 05 March 2007 at 4:12pm
Someone posted the average weight of various thicknesses of ply the other day..don't know where though. Search it up and you'll be able to  work it out..
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mircea Bartic Quote  Post ReplyReply Direct Link To This Post Posted: 05 March 2007 at 5:00pm
I would appreciate somewhere in the neighborhood of 120-140Kg / unit
Ex Nexus_3
Post Options Post Options   Thanks (0) Thanks(0)   Quote staiper Quote  Post ReplyReply Direct Link To This Post Posted: 05 March 2007 at 6:27pm
.. 95-100kg with PD1850 in cabinet
Edited by staiper - 05 March 2007 at 6:30pm
SmokeyJoe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SmokeyJoe Quote  Post ReplyReply Direct Link To This Post Posted: 05 March 2007 at 9:28pm
I'm lovin' that design staiper! Its the best i've seen on this forum in a long time!
I'll probably build a pair for fun in the summer, do some outdoor parties with them...can you smell that barbecue...
And i'll have a spare pair of PD186's to load them with, hmmm, this is gonna be fun!
- Joe.
Post Options Post Options   Thanks (0) Thanks(0)   Quote madboy Quote  Post ReplyReply Direct Link To This Post Posted: 06 March 2007 at 1:22am
and little bit from me:)
for this cabinet  i must use HPF tuned about 26 ~ 33 Hz  or NOT?
This page was generated in 0.062 seconds.
