Hog ?? |
Post Reply | Page 12> |
sn95
Registered User Joined: 10 March 2013 Location: USA Status: Offline Points: 351 |
Posted: 23 May 2016 at 4:05pm |
Sorry for asking such a simple question but after days of searching I can't find the answer and my laptop is broken so I can't do a sim . My question is will a B&C 18nw100 work in a hog ?
Father-Francis
Old Croc Joined: 24 October 2007 Location: Kenya ,Denmark Status: Offline Points: 2760 |
you have it aready or you want to go buy some ?
sn95
I already have to
Edited by sn95 - 23 May 2016 at 7:26pm |
Father-Francis
what kind of system are you building , cause Id better use this one B&C 18TBX100 18 inch. and use those for something else ,
sn95
The primary use of the system it's just for personal I don't run a sound system and I don't need you and it's just for my own personal use. And I have looked at the TBX yes I know that that is one of the recommended drivers For it but to me the NW looks like it should perform better but then again I don't have a whole lot of experience
Father-Francis
put them in power up and find out they look like good drivers
MarjanM
18NW100 is the NEO variant of the TBX100
sn95
Looks that way but more BL and lower Qt/Qe
Edited by sn95 - 23 May 2016 at 8:53pm |
t.geessounds
Young Croc Joined: 10 May 2010 Location: US... New york Status: Offline Points: 908 |
Thanks(1)
MarjanM
ooops
SouthwestCNC
Hi Guys.
Anyone had any issues with the hog plan?. I have drafted it into cad but the layout dimensions dont seem to correspond to the panel dims for panel A. Or im missing something here. Any idea where ive messed up or is there a known error in the plan. Cheers
Edited by SouthwestCNC - 28 June 2016 at 2:11am |
SouthwestCNC
Okay looks as the plans pretty loosely drawn correct angle can only be 37.28 deg with the 392 corrected and 424 added. More of a problem for redrafting than cutting into panels really. Unless you can measure very accurate angles and make your rebate from the cut panel dimensions. Unlikely you would without laying rest of the panels out but could be in a bit of trouble if you did.
Apologies for hijacking the post. Edited by SouthwestCNC - 28 June 2016 at 2:46am |
