Home setup advice when living in a city |
Author | |||
nejten
Registered User Joined: 04 November 2019 Location: Belguim Status: Offline Points: 75 |
Posted: 29 July 2020 at 2:15pm |
Greetings everybody
I have been thinking about building a small soundsystem for home use. The problem is I live in the city in a row house where it is impossible to play very loud music, especially loud bass. So my question is: what setup would you guys recommend to me that has a nice fullrange sound (still with good bass since i play dub/reggae) but wont piss of the neighbours? Any recommendations/ advice are welcome! Bless
From small acorns oak trees grow.
bob4
Open baffle for bass.
dj jammin
Young Croc Joined: 10 April 2010 Location: southampton Status: Offline Points: 770 |
A good set of headphones!!
Reverence Sound system
Conanski
Sad... but so true.
mobiele eenheid
Old Croc Joined: 15 August 2004 Location: Netherlands Status: Offline Points: 1568 |
Sitting close to your sub. I also live in a row house, with a 12" sub about 50 cm from my feet. It helps a bit that it's a (series tuned 6th order) band pass with a small radiating port but distance is key. You could mount a sub under or next to your seat, you can even use multiples spread throughout a room to cover larger areas (which can also have the benefit of each exciting different room nodes).
madboffin
Old Croc Joined: 03 July 2009 Location: Milton Keynes Status: Offline Points: 1538 |
mobiele eenheid has the right answer...
Peter Jan
Young Croc Joined: 16 December 2008 Location: Belgium Status: Offline Points: 1019 |
And add a shaker/buttkicker if you want/need/like more "feel".
Being as close as possible to your speakers, is about the only way if you don't like the headphones/in-ears/optional shaker. Might still excite some neighbours when turned up though, but at least there's a good fighting chance you could get away with it. |
nejten
Thank you to everyone for the suggestions/advice! Will probably consider mobiele eenheid’s advice since a pair of headphones just is not the same in my opinion...
