  New Posts New Posts RSS Feed - horn extension
horn extension
seeker_23 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote seeker_23 Quote  Post ReplyReply Direct Link To This Post Topic: horn extension
    Posted: 25 June 2006 at 11:55am
want to build a horn extension for a pair of 1850 horns have seen them before but unable to find any plans as such..
cud some one please point me in the right direction ... or know of any..
and i dont want the funktion one horn extensions
sorry if this has been posted before.
just looking for some advice
Mark James View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mark James Quote  Post ReplyReply Direct Link To This Post Posted: 25 June 2006 at 12:02pm
yes isnt this supposed to be in the making? an extra 4<5hz would be nice!
insert silly sentence here
Post Options Post Options   Thanks (0) Thanks(0)   Quote seeker_23 Quote  Post ReplyReply Direct Link To This Post Posted: 25 June 2006 at 12:03pm
well ive seen it already.. theres two 1850 horns facing towards each other. and the extension makes it look like a massive w bin...
wondering if anyone knows of the plans...?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mark James Quote  Post ReplyReply Direct Link To This Post Posted: 25 June 2006 at 1:06pm
wher did you see this? [im not doubting, id like to have a gander too!]
Post Options Post Options   Thanks (0) Thanks(0)   Quote seeker_23 Quote  Post ReplyReply Direct Link To This Post Posted: 25 June 2006 at 1:08pm
on this site but i searched for the other day coz ive got the credential to build big at the mo...
and havent found it since?
its anoying. coz i have seen it aqnd now its gone.. just typical sods law!!!
Gramps View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gramps Quote  Post ReplyReply Direct Link To This Post Posted: 25 June 2006 at 2:02pm
I would've thought that you could probably work out a design fairly easily on horn-resp... Infact I'm going to make it my job over the next few days to do so, as I'd love to make some for my Looneys!
If I can't work out how to do it with that I might have a go at designing some using brain power. Was speaking to a guy from Funktion 1 recently, and he said that the expansion rate of the horn really wasn't overly crirical for subs, so I figure if it doesn't look to stupid it should work ok... Can get it tested properly anyway.
Post Options Post Options   Thanks (0) Thanks(0)   Quote seeker_23 Quote  Post ReplyReply Direct Link To This Post Posted: 25 June 2006 at 2:08pm
wud be intresting to see wot u come up with
will u share ur findings. if not cud u send a pm when u do ..
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mark James Quote  Post ReplyReply Direct Link To This Post Posted: 25 June 2006 at 2:37pm
as i said before, im very damned interested...  i know of a few 1850s that could seriusly benefit from this!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gramps Quote  Post ReplyReply Direct Link To This Post Posted: 25 June 2006 at 2:46pm
I'll post all the details up here.
Just thinking about the practicalities of such a device, and its going to mean having a number of holes made in the bins. Firstly the bins will have to be secured together, then the flare extension rigidly to them, which will involve making at least 4 holes (which can be blanked of when not in use) for bolts to fit through, which I'm not overly keen on.. Are there any other ways of temporarily securing things to cabs which I've somehow missed?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mark James Quote  Post ReplyReply Direct Link To This Post Posted: 25 June 2006 at 4:08pm
maybey a clamp or something?
Post Options Post Options   Thanks (0) Thanks(0)   Quote seeker_23 Quote  Post ReplyReply Direct Link To This Post Posted: 25 June 2006 at 4:55pm
a rachet or some srt of hook??
jethrocker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jethrocker Quote  Post ReplyReply Direct Link To This Post Posted: 25 June 2006 at 5:37pm
You could try a heavy duty version of the kind of fitting generally used on flight cases, with the twisty handle which pulls the two sections together. I'm sure I've seen some pretty large ones around which should do the job.
