Horn for 12MB1000 |
Page <12 |
meko
Posted: 01 March 2012 at 8:21pm |
does anyone have any info on this?
I'd really appreciate it. thanks! |
hond
Joined: 10 October 2009 Location: Louvain BEL Status: Offline Points: 619 |
Posted: 19 March 2012 at 12:07am |
I suggest you go learn about how to design a horn.. there are threads about programs like hornresp which help you with the math and the sims
Wrek0ne
Joined: 10 February 2011 Location: Cambridge Status: Offline Points: 746 |
Posted: 23 April 2012 at 2:45pm |
I can help you out with a design that I have (just) finished that may help but the 12" will play from around 100-300Hz in a band pass design, with another horn loaded 10" playing from 300-1kHz. The design has been made with the same foot print a the MT112, and is only around 15cm taller. PM me if your interested and ill finish the Sketch Up and send through the details (things still need to be tweaked but its 95% done in its current state)
>>>I also haven't tested this driver in it but I have had success with most other drivers, and if you are interested I could sim this for you<<< |
Poll this!
rubric
Posted: 01 March 2021 at 9:57am |
Any chance you could share the design/sim on this one? Currently trying to design a horn in hornresp for the 12mb1000 and am having a bit of trouble - thanks!
VECTORDJ
Joined: 11 June 2006 Location: United States Status: Offline Points: 585 |
Posted: 01 March 2021 at 12:03pm |
JBL 4512 horn......just google for plans...easy to make and cranks out 100 Hz to 1200 Hz approx. Use two stacked on each side of stage..............................VECTORSONICS
Page <12 |
