  New Posts New Posts RSS Feed - Horn length in Horn Response
criss View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote criss Quote  Post ReplyReply Direct Link To This Post Topic: Horn length in Horn Response
    Posted: 30 December 2005 at 4:21am
I have recently downloaded Hornresp, a very good program to simulate Horn Design,(this compliment goes to David J McBean).
Can some Kind Hearted Horn Guru help me how to calculate the length of the horn, for a particular design (i.e. say punisher horn). I want to know how to calculate the different conical sections to enter for the folded horn segments.
Thanks,
Criss.
minaximal View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote minaximal Quote  Post ReplyReply Direct Link To This Post Posted: 30 December 2005 at 9:45am
simple, measure down the middle of the flares on the designs (roughly middle anyway) and maybe add on a bit up to 10% i dunno how walt dealt with end correction, where the horn flare theoretically carries on beyond the limitation of the cabinet/horn mouth, until the soundwaves realise there are no boundaries any more.
Edited by minaximal - 30 December 2005 at 9:46am
tb_mike View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tb_mike Quote  Post ReplyReply Direct Link To This Post Posted: 08 January 2006 at 11:43pm
The end correction amounts to half the mouth circumference apparently.
_djk_ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote _djk_ Quote  Post ReplyReply Direct Link To This Post Posted: 09 January 2006 at 2:53am
"The end correction amounts to half the mouth circumference apparently."
Doesn't make any sense.
The mouth of an array of modular bass horns needs to have a circumference of 1W, about 35' in 4Pi for 32hz. In 2Pi this would be about 8-3/4' wide by 4-3/8' tall, close to a four stack of Lab 12 cabinets (a six pack would be 115%).
They will really start going to town above the 1/2W length (mouth to throat). I might spot you 1/2 of the width of the horn mouth for end correction (very generous). So with the above example we would need an overall length of 17' less 4-3/8', or 12-5/8' total length inside the box. Hmm, how long is a Lab 12 from the throat to the mouth?
djk
