  New Posts New Posts RSS Feed - Horn physics.
Horn physics.
gen0me View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gen0me Quote  Post ReplyReply Direct Link To This Post Topic: Horn physics.
    Posted: 14 July 2017 at 12:46am
I wanted to share something here.
It went into my mind reading
You can change the response with EQ but only in one position - if your directivity is way off at certain frequencies then you aren't going to fix that with filters, especially if you're not a serious whizz.
Here as we move from the center axis horizontally top response is rising and vertically falling. Could be good to know
There is also some waste banding here.
Post Options Post Options   Thanks (0) Thanks(0)   Quote gen0me Quote  Post ReplyReply Direct Link To This Post Posted: 14 July 2017 at 12:56am
Im curious if it happens on some wide x narrow dispersion "pro audio" horns like 120 wide.
Edited by gen0me - 14 July 2017 at 12:57am
darkmatter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darkmatter Quote  Post ReplyReply Direct Link To This Post Posted: 14 July 2017 at 4:29pm
You probably need to give some details of the horn geometry in order for this to make sense to people in context...
Post Options Post Options   Thanks (0) Thanks(0)   Quote gen0me Quote  Post ReplyReply Direct Link To This Post Posted: 14 July 2017 at 5:19pm
It was like top one but wider horizontally.
Thats the bottom one. Narrower horizontally. The bend near mouth is for waste banding.
Edited by gen0me - 14 July 2017 at 5:25pm
