  New Posts New Posts RSS Feed - Horn to use?
Horn to use?
Hugo Biermann View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hugo Biermann Quote  Post ReplyReply Direct Link To This Post Topic: Horn to use?
    Posted: 07 November 2005 at 12:08pm
For the X15, should i go for the PH220 or the PH3220? The driver will be a BMD 450. Wich is smoother?
ceharden View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ceharden Quote  Post ReplyReply Direct Link To This Post Posted: 07 November 2005 at 12:17pm
Although I'm yet to try it out, I've just bought some 18Sound 1086XT's.  I'm expecting very good results.  PH220 is very similar (read practically identical) to an RCF H100 which is a very well behaved horn.
Timber_MG View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Timber_MG Quote  Post ReplyReply Direct Link To This Post Posted: 10 November 2005 at 12:28am
Except that P.Audio get the throat size wrong on the PH220 sometimes. I would get on the Phone to Audio Geometry (if you have no luck with the locals try Max in Joburg, one of the fewer times you will chat to someone locally who knows his stuff)
The 18Sound Elyptical waveguide on P.Audio Winner D63 is what I'd go for if you can squeze it in. Should be perfect for your 15" 2-way if the driver gels with the waveguide.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ceharden Quote  Post ReplyReply Direct Link To This Post Posted: 10 November 2005 at 8:20am
Check out the response plot in the multipurpose monitors thread.  DE250 + 1086XT = flat from 4-14kHz on and off axis.  Directivity increases above 12kHz but nothing to worry about.
I might stop raving about these horns sometime in the new year!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Timber_MG Quote  Post ReplyReply Direct Link To This Post Posted: 10 November 2005 at 10:58am
yeah, but the man is also on a budget. The big 18Sound waveguide is a fair bit more likely to play ball with the 15 for numerous reasons.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ceharden Quote  Post ReplyReply Direct Link To This Post Posted: 10 November 2005 at 5:21pm
Ah, you mean go 1.4".  Looking at the specs tho you don't seem to be able to take the WN D63 on the 1.4" any lower than the BMD450 on the 1" waveguide.
I wasn't saying to use the DE250 as it is a bit pricy, but BMD450 on 1086XT is an option surely???
Post Options Post Options   Thanks (0) Thanks(0)   Quote Timber_MG Quote  Post ReplyReply Direct Link To This Post Posted: 11 November 2005 at 5:28am
Yes. I am not too sure about the mechanical handling of the 2.5" diaphragm 1.4" exit P.Audio (one of the reasons to ask Alex) but I would imagine that it should be better than a normal 1.75" 1" exit and the waveguide has a mouth more likely to integrate properly with the 15 (if teh size isn't a problem). I have heard that the 3" dia 1.5" exit P.Audios work alright on the 18Sound waveguide if you can live with the response falling like a rock above 12kHz.
Edited by Timber_MG - 11 November 2005 at 5:29am
