Horn Tweeter Box |
Page <1 234 |
Lucasdude ![]() Young Croc ![]() Joined: 16 March 2013 Location: London Status: Offline Points: 604 |
The dispersion pattern of HF horns is the horizontal and vertical coverage in degrees. Stereo imaging is how accurately a stereo signal is reproduced by a pair of speakers. If you intend just to plonk a load of boxes in one spot, then you don't need to worry about stereo. A single stack will be in mono, so the HF and MF sections can be driven by just a single amp channel each. So the minimum number of amp channels required for an active 3 way mono system is 3, for an active 3 way stereo system is 5 ( bass frequencies are omnidirectional, so they don't need to be run in stereo).
SnailSpace ![]() Registered User ![]() ![]() Joined: 08 December 2022 Status: Offline Points: 154 |
I will be using as both 2 stacks and 1 stack.
What would happen if I had x2 horizontal 1 above the other? (I’m not questioning you just if I know why you don’t do something it makes more sense!) I have seen when I look at other Sound systems rows of horizontal horns I presume this is because they have more output below to balance? Or that they like more high?
KDW32 ![]() Registered User ![]() Joined: 09 April 2010 Location: Green Hell Status: Offline Points: 403 |
Snaispace get a copy of the old Yamaha sound reinforcement book..
I’ll take a look Thanks
You'll will learn a lot from from it especially coverage and dispersion etc. It's a handy little 'bible' I think I got it it 25 years ago I'm sure they update it a bit but a lot of useful information. Second hand hand on eBay won't cost many pence.
Still quite expensive on eBay in uk as only copies are in US. It’s nice to have a hard copy as it’s easy but I’ve searched and found it on GoogleDrive as a PDF https://drive.google.com/file/d/0B9Ka-yX8YG6KVEJVNjVpNFVOY0k/view?resourcekey=0-ZVVgTWKylltbOwRVrbU_NA
Nice, some of the questions you been asking are well explained in it. It will give you a good grounding.
Amazon UK have it for £16 Edited by KDW32 - 09 March 2023 at 9:33pm |
Edited by SnailSpace - 20 March 2023 at 10:52am |
Edited by SnailSpace - 20 March 2023 at 10:51am |
Page <1 234 |
