Hornresp 2 drivers/horn paths - one mouth? |
tcourtneyvincent
Young Croc Joined: 04 January 2011 Location: Devon Status: Offline Points: 1146 |
Posted: 13 July 2019 at 9:51pm |
Hi guys, i'm pretty new to Hornresp but think I understand all the main functions.
I'm trying to simulate a horn where two drivers start with separate throats, which then merge to share a single mouth. How would I simulate this? Currently I have selected 2P in driver arrangement and doubled the surface area of each single horn segment in till they combine. Is this correct? Also if I have selected 2P , do I need to drop the voltage to maintain 1w? Has been twisting my nogging for a week or two now! Many thanks!
Edited by tcourtneyvincent - 13 July 2019 at 9:52pm |
mobiele eenheid
Old Croc Joined: 15 August 2004 Location: Netherlands Status: Offline Points: 1568 |
You can drop from 2.83 V to 2 V for 1 W into 2 parallel drivers (square root of 2 lower).
gen0me
If that logic is correct, try simming 2 horns and compare this sim to one horn with double the drivers and double the surfaces.
