  New Posts New Posts RSS Feed - Hornresp noob questions.
Shortrope View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Shortrope Quote  Post ReplyReply Direct Link To This Post Topic: Hornresp noob questions.
    Posted: 05 March 2020 at 1:18pm
Ok folks...this is my first bash at Hornresp.
I'm trying to model a basic 15" vented mid horn cab.
I'm not familiar with what I'm looking at but the diaphragm extension issue is alarming.
Am I making any obvious howlers with my inputs?
Thanks a mill
Xoc1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Xoc1 Quote  Post ReplyReply Direct Link To This Post Posted: 07 March 2020 at 1:24am
I put your parameters in and ran it and you are exceeding xmax at whatever voltage you had set it to for the max spl output . The max spl tool is not so easy to use as you have probably set it to a nominal 500 watts. Far better to use the acoustical power & other windows using a constant voltage as this will give you a better idea of how it is going to work.
If you set the input to a nominal 500w @ 8R (63.25V) you would see that at some frequencies you would be pushing 700w into the driver.
This page was generated in 0.079 seconds.
