(horns) If portability was not an issue |
Page 12> |
Dr Burnz ![]() Registered User ![]() ![]() Joined: 15 August 2005 Status: Offline Points: 100 |
![]() ![]() ![]() ![]() ![]() Posted: 10 June 2008 at 5:17pm |
Hi all,
I've got an idea for a custom sound system for a 250capacity venue, which is rectangular shaped with the stage at one end. My question I have for you Acoustic wizards... If space (lengthwise)was not an issue, and if I wanted to build a straight horn ![]() OR am I being too ambitious? Ideally I want the efficiency of a horn with a really deep cut off. Suited for bass heavy music like dubstep... etc.. And if I can make it look nice and different, that would be a bonus! Thanks. Here's a sketch I made to help you understand what I mean. ![]() |
Disco Stu ![]() Old Croc ![]() Joined: 03 March 2005 Location: United Kingdom Status: Offline Points: 2487 |
If it were me I would try and build it curved so it goes around the edge of a room where you could embed seating to make it look less incongruous. That would in turn make it folded, but it could be made to look very attractive.
There is a practical limit to the amount of sensitivity you can get out of a box, I doubt you will be able to exceed 108dB from a box, and you would probably need about a 5-6m horn to get that. Stu |
All you need to know is:
Sensitivity + Power Handling - Power Compression = Max Output My acts: www.myspace.com/thebowiexperience www.myspace.com/scheisseelektronisches |
doober ![]() Young Croc ![]() ![]() Joined: 03 January 2006 Location: Cornwall UK Status: Offline Points: 1118 |
Blahblahblah
WOW! Something like that would be MINT! but, maybe not so big. I guess by folding, I'd get a longer path.
Hey doober, did you build that horn? Where is it? I'd love to hear what it sounds like. I guess I could rip the stage apart and utilize that space. I'd be happy to get 106dB efficiency as long as its all the way down to 30-35Hz. That would be plenty. Basically, I have a friend with a venue which she is loosing money on, So I thought why not make it a project to get the best sound for little money (which I'll be investing, or using my current rig). So I thought, why not build a big horn out of cheap material like MDF and put some nice drivers in it e.g. the new void 1200w 18" drivers or something... If it doesn't take off, I'll take my drivers back and leave the horns. Plus, It'll be an interesting project for me. I kind of know how to use Hornresp. |
MarjanM ![]() Old Croc ![]() ![]() Joined: 10 February 2005 Location: Macedonia Status: Offline Points: 7745 |
How big is the stage. Can you fold it under the stage?
darkmatter ![]() Old Croc ![]() Joined: 26 February 2005 Location: LDN Status: Offline Points: 2425 |
Are folds sometimes beneficial in horns like this because folding filters out higher frequencies? Not something I know enough about. |
If you are building a sub (30-100Hz) folding can not affect the frequency response because the valve length is too big. For upper range they do act as a bandpass filter.
Main benefit in folding is to make the box more compact.
The stage is about 8m square. Or so, not measured it properly yet.
Edited by Dr Burnz - 11 June 2008 at 1:12pm |
opus jody ![]() Young Croc ![]() Joined: 06 June 2006 Location: United Kingdom Status: Offline Points: 1246 |
![]() sorry, i'm just showing off now! ![]() since gatecrasher sheffield burnt down, this is the only one left now. |
Improvised Hardware Music http://vimeo.com/user9389813/videos
Is that 2 separate horns with 3 drivers in each?
That design looks pretty much ideal to me. If I can load a couple of drivers per horn, It would save even more space! If the subs go under the stage, then I'll have to keep them to a maximum of 50cm high or so. Thanks for the posts guys, It's giving me more ideas of what I want to do. ![]() Edited by Dr Burnz - 11 June 2008 at 2:48pm |
That's not mine, it was built by the genius/madman known as roborg on this forum, but I think it's long gone now. There are a few threads about it somewhere, search for 'ravehorn'. Jody- does that horn ever come out to play? I'd love to hear it sometime if you use it around here. |
Blahblahblah
Page 12> |
