How do I wire in series speakers in different box |
rayrainx
Registered User Joined: 27 December 2016 Location: nigeria Status: Offline Points: 46 |
Posted: 03 June 2018 at 9:34pm |
i just built 4 186 folded horn cabs..and I have them loaded with an 4ohms tit drivers...I need to wire two sub's each in series to have an 8ohms load pair per side and bring them back in parallel to have all 4 cabs @4 ohms load..I plan to use only use one amp rated @ 5000watts bridge mono 4@ 4ohms...I would easily do these internally if two drivers are in a single cab ..but now they are all 4 separate cabs..how can I achieve the series wiring externally using only neutric speak on connectors and wire without flooding the back of my cabs with flying wires? Any fast ideas please?
djeddie
Have a separate box with one "in" speakon and two "out" speakons that are wired in series
RC1 Sound System
Registered User Joined: 03 February 2012 Status: Offline Points: 247 |
Put the amp in parallel or stereo and just put two 4 ohm cabs linked in parallel on each channel. An amp that does 5000 watts bridge at 4 ohms should do 2500 per channel at 2 ohms instead. A 4 ohm load on a bridged amp presents pretty much the same load as two 2 ohm loads on a stereo amp.
Also, the two 2 ohm loads is a safer option as if an amp channel fails you only lose half your bass. Also with the bridge series/parallel configuration you risk a very unbalanced load between the three remaining bins if a driver ever failed.
