How do studio monitors achieve flat respone |
H3ct0r
Registered User Joined: 08 February 2022 Location: Cambridge, UK Status: Offline Points: 11 |
Posted: 12 April 2022 at 3:32pm |
I’ve been looking into how active studio monitors can achieve a nearly flat frequency response. For Example if you search up the frequency response of the Yamaha HS-8 it is nearly dead flat. Is this done purely in hardware and cabinet design per am I right in thinking that they firstly make it as flat as possible in hardware, then they add a digital eq which takes the speaker input, digitalizes it and applies an eq that is the opposite of the frequency response in order to even out minor lumps and bumps and then convert that back into analog before being amplified?
toastyghost
Thanks(1)
For most of them, the former.
On modern units with DSP, a bit of both. |
nojunk
Registered User Joined: 12 January 2008 Location: Germany Status: Offline Points: 65 |
Sonarworks SoundID
toastyghost
Can’t make up for bad acoustic design in the first place. It’s a room ‘correction’ tool that works over a very small listening area. Same for applying an inverse FIR filter from a measurement. It's a 1D solution to a 3D problem. There's a lot more to getting a good result than just measure, invert, apply. You have to actually understand which element of the loudspeaker design is causing which effects. Then treat each of those with appropriate methods for your goals & limits - including budget, size, and time. |
MarjanM
Those Yamahas might be flat but they are still some of the worse sturio monitors out there.
