How high is your stack? |
Post Reply | Page 123 4> |
Khyber
Registered User Joined: 28 October 2017 Location: Whitby Status: Offline Points: 89 |
Posted: 18 January 2018 at 10:38am |
Hello all, just a quick one... What are the heights of each section of your stacks (i.e. 2 subs stacked then kicks then tops) and then total height top to bottom. Just curious to see what heights people use and what is ideal for each frequency section. (maybe include pics with dimensions scribbled on?)
cravings
i just try to get upper mids and highs above head height really. a stack of 2.5M high / 8ft will fit in nearly all rooms. that's what i've been aiming for anyway. other than that it doesn't matter what height your subs are etc.
matty w
Young Croc Joined: 27 August 2008 Status: Offline Points: 798 |
The higher you get your tops the less you will take people's heads off up front !
Ofcourse with appropriate tilt and providing you have enough spl ! Will also minimise comb filtering in low mids that sets in the further you go back |
Black to black , red to red , blue to bits ....
PinHole
Registered User Joined: 14 September 2013 Location: behind you Status: Offline Points: 93 |
..hm.. how high? As I know it may depend on quality of bud.
Signature is important. So I always write something in this dedicated field.
luton_soundman
Old Croc Joined: 03 August 2010 Location: Bedfordshire Status: Offline Points: 4539 |
Yeah ideally mid and high mid just above headheight.
Sinai Sound
Young Croc Joined: 09 November 2009 Location: Sheffield Status: Offline Points: 631 |
Approx 2.55m in height
It's a bit too tall for some venues occasionally. A modular setup would make that slightly better I try to angle the mid tops down a little bit where possible Edited by Sinai Sound - 18 January 2018 at 2:54pm |
Dub Specialist Sound
My good bredrin
Trensetter sound , i allways call his stack Kilimanjaro lol |
Khyber
Nice rigs you lot :) im on the right track then. My current design stands just under 3m. The bottom of the mids are around 2m. with the kick section right in the face at 1.7m with adjustable tilt comp horns.
paulus
Old Croc Joined: 14 December 2005 Location: SOUTH BIRMINGHA Status: Offline Points: 3181 |
it act had broke me after 8 years to let those mid top cabs go,:( but in 80% of venues i had to just put the mids on top of the scoops and have kick in the middle, i really did not like the sound of this so after lots of thought let them go , know we have a easier stacking function which fits 99.9% of rooms
TRENDSETTER SOUND SYSTEM
Bro
paulus
still can not get the bullets and comps on bu this is a very low room and up there still have some jbl 2" comps and jbl bullets :)
Edited by paulus - 18 January 2018 at 4:08pm |
Khyber
nice :) i am designing mine so i can re-arrange and half the sub height and arrange them 4 side by side width ways instead of 2 on top of 2. that will lose nearly a meter for low ceilings.
