How low will 8x 186horn go? |
Aztor ![]() Registered User ![]() Joined: 22 September 2010 Location: Norway Status: Offline Points: 376 |
![]() ![]() ![]() ![]() ![]() Posted: 05 April 2011 at 12:04am |
Hello
How low will 8 186horn go? Stacked 4 high. |
Calculus ![]() Young Croc ![]() Joined: 03 January 2005 Location: Newcastle Uk Status: Offline Points: 1105 |
Learn to use horn resp. and you'll have a answer in no time.
Always a compromise, You can't have everything...
Where would you put it all. |
About 45 hz then. I can use it, but i thougt some had experience with 8 horns.
mykey- ![]() Old Croc ![]() ![]() Joined: 03 March 2010 Location: ID/UK Status: Offline Points: 6114 |
as low as you would ever need them to go
The Builder ![]() Old Croc ![]() Joined: 03 January 2010 Status: Offline Points: 3107 |
All this sub 40hz stuff, 65hz is where it's at with a LOT of music.
Try a test tone and see
It just is.
Thanks
Is there a rule of thumb? What should be suggested cutoff? |
I recon 45 to 120, never owned them though, only old CV similar, but that was many moons ago before dubstep ;)
It just is.
Ok, i'm currently using 4x 186 at 48-150 hz.
saladmanscott ![]() Registered User ![]() Joined: 19 December 2010 Location: Cambridgeshire Status: Offline Points: 17 |
what is the SPL like with that set-up. how do they sound?
Scott |
tomschute ![]() Old Croc ![]() Joined: 15 May 2006 Location: Mid Wales Status: Offline Points: 1817 |
unless you model the actual horn that 8 cabs creates horn resp will not paint an accurate picture at all. |
www.stableaudio.co.uk Speaker Building Services |
spongebob ![]() Young Croc ![]() Joined: 20 October 2010 Status: Offline Points: 1393 |
Thread Jack :D
Could someone estimate 6x 1850's for me (Void V18 loaded) Danke |
