How many G-subs per 2x HD15? |
Post Reply | Page 12> |
Aztor
Registered User Joined: 22 September 2010 Location: Norway Status: Offline Points: 381 |
Posted: 05 May 2011 at 5:22pm |
Hello
Planning to make a single "dance" stack consisting of 2x QSC K12 or 2x MT121 2x HD15 (PD1550 Loaded) 2-3 Gsubs (PD 186 Loaded) How many Gsubs will I need? Is 2 enough? Is 3 overkill? Similar threads is wanted. I haven't found anything on google or in here. I haven't read all, but I have read the newest threads in the "HD15" forum. Uses are inside. Thanks! Edited by Aztor - 05 May 2011 at 5:23pm |
GekoMusic94
Registered User Joined: 03 February 2010 Location: Italy Status: Offline Points: 469 |
I think with 2xGSubs per 2xHD-15 you'll be fine... That's my ideas though..
Giacomo. |
https://soundcloud.com/dj-uber
bass*en*mass
Thanks(1)
what do you need hd15s for if you use tops that can be crossed as low as 120hz?
Any reflex bin will work well crossed over that "high" and will sound better than mixed up with a kickbin. (more DSP and more amps needed for the hd15s, just put that money into good reflex speakers and youre sorted... ) |
Aztor
The HD15 is just for more kick.
The Builder
Old Croc Joined: 03 January 2010 Status: Offline Points: 3107 |
Na, leave the HD's out.
If you must do kick, do three G Subs standing up on end with one USB laying across top.
It just is.
Aztor
USB will give better kick than HD15?
Kick is not a must, but I think they look cool. And I want to try some new builds. Edited by Aztor - 06 May 2011 at 12:28am |
specialjustin
Young Croc Joined: 18 November 2006 Status: Offline Points: 555 |
Cat amongst the pigeons!! I assuming you don't currently have any of these speakers? If so, maybe you could look for what would be the best complete solution? What gear do you own at the moment? |
Meat
Old Croc Joined: 05 June 2009 Location: Manc Status: Offline Points: 1514 |
I think builder is right, but it'd be a neater stack with all same size boxes lying flat. You may have to resize the g-sub to do that but it'll look nice. You could also build 1/2 USBs so you can do a stereo stack or use them for little things where you want wacking kickbass and not much else.
The Builder
Thanks(1)
I have G Subs, X12's and ES18bph amongst others.
USB/ES18-BPH I have experience with. Heard HD's many times, no contest IMHO, UBS/ES win.
Before the diciples start, GSub/MT/1850 etc fine cabs.
Progress does happen
Pesronally, if I was building again, and I had to buy new drivers, I would build six ES218 or some naughty but similar F218 variants.
Used drivers for these (non ribbed cone) are however thin on the ground. Edited by The Builder - 06 May 2011 at 9:43am |
It just is.
Aztor
I have build 2x MT121 and 1x G sub. I realy like the sound of both boxes. I have 4x 186 horn. But inside medium sized rooms i like reflex better.
was thinking 2x horisontal Gsubs with 2x hd15 on top, and mid tops on top of that. I think that would be a stack that seem nice, and stands out! What would be better for kick? USB ES18bph HD15 |
bass*en*mass
No special kick-bins needed!
Just built more reflex cabs and fit them with high quality speakers! |
Aztor
kk!
But just one more question! If I would make pure stacks of the 3 bellow. What would be the best choice for kickbin? USB ES18bph HD15 |
