how many ports? |
Bassaddict
Registered User Joined: 18 April 2008 Location: North East UK Status: Offline Points: 308 |
Posted: 16 February 2010 at 11:05am |
with the bracing going down the middle of the ports does this split it into 2 ports or is it still classed as one?
cheers |
The only good system is a sound system.
eltron
Registered User Joined: 21 December 2007 Location: Finland Status: Offline Points: 399 |
It's still only one port. The tuning stays the same as the depth and cross-sectional area remain the same. (Well minus the extra brace, but hey...)
Bassaddict
rito cheers mate
jossdude
Registered User Joined: 16 September 2009 Location: Newcastle Status: Offline Points: 133 |
I was thinking about this the other day.
If instead of having little separae braces, what would happen if you cut on segment the full length of the port. In a scoop it would be quite a complex shape but it could be CNC'd. How would this effect the sound. Would it turn it into two smaller ports? Or would it still act like one big port as they will be identical getting driven from the same driver all in phase?
