  New Posts New Posts RSS Feed - How many Sheets for WSX
dekra54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dekra54 Quote  Post ReplyReply Direct Link To This Post Topic: How many Sheets for WSX
    Posted: 20 January 2018 at 9:44am
Hello Forum,
As the Title says i want to know how many sheets of ply i need aproximately for one WSX bin.
I plan to build a batch of 4 or maybe 8 LOL? Cool. Cause I hate when youre in the middle of construction and realise that im running out of something.....
Also some suggestions for Drivers welcome. (I plan to use the original RCF L18P300 but the Void 18V1000 is also an option. I would prefer something from B&C because i have a real cheap source for drivers from them.)
Greetings from Germany :)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dub Specialist Sound Quote  Post ReplyReply Direct Link To This Post Posted: 20 January 2018 at 10:06am
Have you got a cut-sheet for the 1 box?
if so pm me it, and ill work it out on my software for you
Thumbs Up
Post Options Post Options   Thanks (0) Thanks(0)   Quote dekra54 Quote  Post ReplyReply Direct Link To This Post Posted: 20 January 2018 at 10:33am
Thank you for that kind offer Thumbs Up :)
This was more like a question if someone already did it so no double work ;)
I already downloaded MaxCut and  fiddeling around but if i cant get something useful out from it then i'll maybe take your offer.
(PS: sorry if my english isnt the best at the moment i'm back from a gig and haven't slept LOL)
ychole audio View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote ychole audio Quote  Post ReplyReply Direct Link To This Post Posted: 20 January 2018 at 6:11pm
5 sheets of (48" x 48") ply for a pair of wsx, done 6 boxes so far.
I am ZERIEL'S dad!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote dekra54 Quote  Post ReplyReply Direct Link To This Post Posted: 20 January 2018 at 6:33pm
Thanks Thumbs Up that helps very much to calculate the aproximate costs.
Which driver did you use ? :)
cookie-dj View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cookie-dj Quote  Post ReplyReply Direct Link To This Post Posted: 20 January 2018 at 10:42pm
V18-1000 is supposedly called the WSXtra due to better performance than the original driver
You can't polish a turd!
bass*en*mass View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bass*en*mass Quote  Post ReplyReply Direct Link To This Post Posted: 21 January 2018 at 7:51am
48x48" aint exactly a typically available EU size.. 8x4/250x1250 is the norm, 300x150 aswell, depending on your supplier.. l18p300 is a quite outdated driver imho compared to recent options..
Danny A View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Danny A Quote  Post ReplyReply Direct Link To This Post Posted: 21 January 2018 at 11:37am
the last driver martin used was the DLS1847 which is the B&C 18 TBX100. It does require a mod in the form of spacer to give the front of the driver more clearance as it has a higher excursion than previous drivers.
Brutus View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brutus Quote  Post ReplyReply Direct Link To This Post Posted: 21 January 2018 at 2:02pm
use the spacers, use the B&C 18 TBX100-8 and you are a winner,
in holland we have 255 (244) cm x 125 (122) cm  sheets, and we used 3 of them per cab.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dekra54 Quote  Post ReplyReply Direct Link To This Post Posted: 21 January 2018 at 7:07pm
Thank you very much :)
Awesome that the TBX100 work because i can get it for about 220€.
At the moment im trying to rweork the plan a little bit so i can use 20mm ply (for some reason its much cheaper)
When im finished with the two cutsheets in maxcut i will upload them Thumbs Up
Dennis
