How many watts for V1000 |
C-Audiofreak
Registered User Joined: 12 June 2014 Location: Norfolk uk Status: Offline Points: 467 |
Posted: 31 October 2015 at 9:47am |
Hi guys reading a lot of the posts in this section I notice a few posts saying don't give more than 800watts into certain drivers in this box and given that the original driver was an 800watt driver do I assume that if using the v18 1000 I shouldn't welly it with more than 800watts rms?
cookie-dj
I had 1200w per X1 with voids in them. Even that probably wasn't doing them justice
You can't polish a turd!
C-Audiofreak
So if the driver is only rated at 1000 watts rms anything over and above isn't over loading them then cookie?
cravings
i have mine on pkn xd4000. normally one a side.. so that's nominally 1300w. high pass at 35 though.
C-Audiofreak
So I assume by that you mean they only play to 35hz then 35hz +is over to kicks then cravings?
RUS
No I think he means 35hz high pass to about 70hz + |
cravings
correct rus. i think i'm low passing at about 60 these days.
cookie-dj
High pass = anything higher than said frequency will be played e.g 35hz and above Low pass = anything lower than said frequency will be played e.g 70hz |
C-Audiofreak
Got ya cheers cookie
Mark James
yep hi pass means it allows anything higher to pass low pass anything lower passes [its not a brick wall tho remember it rolls it off not blocks it]
