  New Posts New Posts RSS Feed - How many watts for V1000
C-Audiofreak View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote C-Audiofreak Quote  Post ReplyReply Direct Link To This Post Topic: How many watts for V1000
    Posted: 31 October 2015 at 9:47am
Hi guys reading a lot of the posts in this section I notice a few posts saying don't give more than 800watts into certain drivers in this box and given that the original driver was an 800watt driver do I assume that if using the v18 1000 I shouldn't welly it with more than 800watts rms?
cookie-dj View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cookie-dj Quote  Post ReplyReply Direct Link To This Post Posted: 31 October 2015 at 10:08am
I had 1200w per X1 with voids in them. Even that probably wasn't doing them justice
You can't polish a turd!
Post Options Post Options   Thanks (0) Thanks(0)   Quote C-Audiofreak Quote  Post ReplyReply Direct Link To This Post Posted: 31 October 2015 at 10:16am
So if the driver is only rated at 1000 watts rms anything over and above isn't over loading them then cookie?
cravings View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cravings Quote  Post ReplyReply Direct Link To This Post Posted: 31 October 2015 at 5:33pm
i have mine on pkn xd4000. normally one a side.. so that's nominally 1300w. high pass at 35 though.
Post Options Post Options   Thanks (0) Thanks(0)   Quote C-Audiofreak Quote  Post ReplyReply Direct Link To This Post Posted: 31 October 2015 at 7:35pm
So I assume by that you mean they only play to 35hz then 35hz +is over to kicks then cravings?
RUS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RUS Quote  Post ReplyReply Direct Link To This Post Posted: 31 October 2015 at 7:58pm
No I think he means 35hz high pass to about 70hz +
Post Options Post Options   Thanks (0) Thanks(0)   Quote cravings Quote  Post ReplyReply Direct Link To This Post Posted: 01 November 2015 at 5:17am
correct rus. i think i'm low passing at about 60 these days.
Post Options Post Options   Thanks (0) Thanks(0)   Quote cookie-dj Quote  Post ReplyReply Direct Link To This Post Posted: 01 November 2015 at 5:54am
High pass = anything higher than said frequency will be played e.g 35hz and above
Low pass = anything lower than said frequency will be played e.g 70hz
Post Options Post Options   Thanks (0) Thanks(0)   Quote C-Audiofreak Quote  Post ReplyReply Direct Link To This Post Posted: 01 November 2015 at 8:19am
Got ya cheers cookie
Mark James View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mark James Quote  Post ReplyReply Direct Link To This Post Posted: 01 November 2015 at 11:42am
yep hi pass means it allows anything higher to pass low pass anything lower passes [its not a brick wall tho remember it rolls it off not blocks it]
If you want people to feel the bass then a reflex design is probably best as you get the most air movement per decibel from those.      errrrr yes wtf?
Forum Software by Web Wiz Forums® version 12.02
