  New Posts New Posts RSS Feed - how much power is ok for PD186
CritikalMass View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CritikalMass Quote  Post ReplyReply Direct Link To This Post Topic: how much power is ok for PD186
    Posted: 15 November 2013 at 2:16pm
What's safe to run these drivers at? Looking at an amp that's 3.2Kw per side at 4ohms to run 4
Post Options Post Options   Thanks (0) Thanks(0)   Quote mk2_ginger_biscuit69 Quote  Post ReplyReply Direct Link To This Post Posted: 15 November 2013 at 2:58pm
sounds good, they like a clean 1000w/channel with headroom to spare...
just don't thrash em and they will sound great!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote CritikalMass Quote  Post ReplyReply Direct Link To This Post Posted: 15 November 2013 at 3:24pm
Nice one! You used anything this powerful on them before?
RUS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RUS Quote  Post ReplyReply Direct Link To This Post Posted: 15 November 2013 at 3:29pm
I would also say it depends what amp your looking at, if it's budget, then I'd go for better quality with less power.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CritikalMass Quote  Post ReplyReply Direct Link To This Post Posted: 15 November 2013 at 3:38pm
Tony reccomended the SAE PCM18
Post Options Post Options   Thanks (0) Thanks(0)   Quote CritikalMass Quote  Post ReplyReply Direct Link To This Post Posted: 15 November 2013 at 3:54pm
PCM18
1800W 8ohm per ch
3200W 4ohm per ch
3900W 2ohm per ch
6000W 8ohm bridged
7200W 4ohm bridged
Full webpage with info here
Edited by CritikalMass - 15 November 2013 at 3:55pm
