How to bridge powersoft K2? |
Aymara
Registered User Joined: 05 March 2022 Location: Belgium Status: Offline Points: 23 |
Posted: 19 May 2022 at 8:56pm |
Hi everyone,
I bought an powersoft K2 for my subs and wan't to bridge my amp but don't really know how to do it... In the manual they write: Bridge-tied load connection can be achieved as described in FIGURE 12. In analog mode, only the input of
channel 1 needs to be wired: link channel 2 to channel 1
by means of the link pushbutton located on the rear panel. Do they mean with wired for the positive pole 1+ and for negative pole 2+ on the speakon cable? Or just wired 1+ 1- ? If i press on the link button on the rear panel with 1+ 1- wired i don't hear any louder sound...
Aymara
Aymara
I can't upload the image, its the image on the right under corner on page 12 of this manual: https://www.powersoft.com/wp-content/uploads/2019/01/powersoft_KSeries_uguide_mul.pdf
Tinnitus Rex
Registered User Joined: 31 October 2020 Status: Offline Points: 281 |
Channel 1+ and channel 2+ is normaly the way to bridge a stereo amp, 2+ being the virtual negative for your speakers. On that Amp it is vague .it seems to suguest each speakon has 1+ and 2+ joined together . so you would need 2 speakon plugs , one for + and the other for -.... More importantly !Why do you want to bridge it ??
Edited by Tinnitus Rex - 19 May 2022 at 10:00pm |
"couldn't we just like... use headphones?"
Aymara
If i try that, i don't get any sound...
Aymara
Because then i have more headroom, if i don't bridge my amp doesn't give enough watt....
Tinnitus Rex
what speakers are you trying to destroy? I just looked at the manual and in section J it clearly shows you use 2 speakons one wired 1&2 + and a the other speakon wired 1&2 - using input one only with link switch on, Next question "how much for recone of........?" 4800 W @ 4 Ω Frying tonight ! Edited by Tinnitus Rex - 20 May 2022 at 5:38pm |
Aymara
It's for 2x Void v18. So that is 2x 1000w/8ohm.
VECTORDJ
Young Croc Joined: 11 June 2006 Location: United States Status: Offline Points: 515 |
VECTORSONICS Auburn, Maine USA for woofer recone work......Thanx.
