How to stop a sub from trying to walk off? |
Post Reply | Page 12> |
Author | ||||
Sam Bass
Registered User Joined: 10 May 2016 Location: UK Status: Offline Points: 17 |
Posted: 20 October 2017 at 12:12am |
I have two single 18TBX100 reflex loaded subs, I have used subs exactly the same as this perviously and because they weigh less than a 218 reflex box they start moving around pretty quick when you start getting close to its RMS power consumption. I have rented L'acoustics SB28's from SSE in the past and these boxes came with really smart personalised rubber matting with the hire company name etched out with very good non-slip properties and protective qualities. Does anyone know what I'm talking about or where this sort of thing could be obtained? Or am i better off sticking to multiple rubber feet?
If anyone's seen Texas Ranger George Herold or Ranger Sergeant Richard Ware tell them I'm still looking for them...
valve head777
Old Croc Joined: 27 July 2012 Location: East Sussex Status: Offline Points: 1780 |
We used to use car rubber mats, quite sticky rubber.
Zik
Registered User Joined: 20 June 2017 Status: Offline Points: 20 |
Rubber feet never fail, or ratchet strap to a pallet.
cravings
Old Croc Joined: 30 January 2007 Location: Ireland Status: Online Points: 7441 |
surprised no one's suggested more bracing yet. the less the panels vibrate, the more effective it is as a speaker.
just sayin.. but yeah. there's rubber non slip stuff you can get cheap in home diy type places. works well. |
MarjanM
If they walk, that means bottom panel is vibrating too much. So they basically start jumping.
Racks&Stacks
Registered User Joined: 10 February 2006 Location: Germany Status: Offline Points: 204 |
isnt it also a weight vs output issue?
SamV
Old Croc Joined: 21 October 2008 Location: London Status: Offline Points: 8707 |
Rarely.
You can also use blutack lol. Done that twice.
ceharden
Definitely means the subs need more bracing.
I'm very pleased with the twin 18" design. When running hard, the only place you could put your pint without it walking off onto the floor was on top of the sub itself! Non slip tool mat is a good solution: However, be warned. DO NOT use it for installs... Venue I used to work at used it between their 3 F2B's, ratchet strapped them up and left them for a few months. When we tried to dismantle the stack we were left with a 6x15" bass bin! We were lifting and dropping them, using crowbars and it took a lot of brute force and ignorance to separate them. |
nickyburnell
Revered loop of gaffer abut 3" long? in 4 corners
Sam Bass
Its not to late to add more, all be it retrospectively. This is something that I considered while making them, i use an inherently strong and well braced design with a 25mm baffle to try and avoid this.
Marjan, I have seen the internal bracing I believe your responsible for put in the BA218. WOW.
Which design is this?
I wanted something FAR more heavy duty, something that could be permanently installed on the boxes.
cravings
i've seen boxes screwed into wooden floors before.
White Noise
Registered User Joined: 05 January 2015 Status: Offline Points: 54 |
As mentioned, if your subs walking around, its probably resonating the panels too much and needs more bracing. The box should transmit all that energy into the air.
+1 for the pint on the box too haha :) Someones comment at the bottom of their posts on here is a good one... ''A true subwofer should be the only thing in the room not shaking.'' |
