  New Posts New Posts RSS Feed - Hz
Hz
Chewit View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chewit Quote  Post ReplyReply Direct Link To This Post Topic: Hz
    Posted: 22 May 2020 at 5:45pm
Iv got 2 15ā€ ported reflex subs loaded with 400w eminence delta drivers! Running these on top of scoops. What would be best to set the HP and LP too? Any help would be great :)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Earplug Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2020 at 6:16pm
What do you have on top of those? That would influence the LP. HP at 80/90Hz?
Sinai Sound View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sinai Sound Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2020 at 6:36pm
With totally guessing everything,
90hz high pass, 200hz low pass
Both 24db LR filters
Depending on how good the reflex box is, you might be able to go down to say 70hz.
Then depending on what's on top of it, you could again lower the LP to say 150hz
Something like that :)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chewit Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2020 at 6:37pm
Iā€™m getting some mt121s
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chewit Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2020 at 6:38pm
Thank you!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Earplug Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2020 at 9:43am
+1
That sounds about right for what you have.
