I Hate Filling and Sanding! |
Post Reply | Page <1234 7> |
adambomb
Been enjoying the sun again... All the HDs are now done, ready for paint (this Saturday I spent 6 hours on sanding them again and the X1s)... have put even more glue into all the joints (not really nescecery but I thought I might as well).. also rounded the doors on the X1s)... burnt my back big time! HOT HOT HOT!
Being sprayed this week, and as long as PD honer the delivery time they gave me I should have everything assembled this Sunday coming.
More pics to follow!
adambomb
Just phoned PD.. and confirmed my drivers will be with me on Thursday at the latest! Cool Beans!
adambomb
Drivers all arrived,bang on due date.. lovely!
More pics :
Right...I'm off to carnival!!
Rockin
Young Croc Joined: 02 April 2007 Location: Rotherham Status: Offline Points: 737 |
Lovely job
gingerbiscuit69
Registered User Joined: 23 September 2005 Location: United Kingdom Status: Offline Points: 2540 |
cant wait for the rave!!
chrismca07
Registered User Joined: 27 June 2007 Location: england Status: Offline Points: 272 |
can you use these as a general all round sub#?
adambomb
Rave????
They are 2 HD15s in one cab.. have a look at the plans section... they are primerely kick bins but in large piles (3 doubles or more) you can use them as general bass bins.. (but not really as subs, they wont go low enough).
chrismca07
oh right whats the difference between a sub and a bass bin... i was thinking of using them for rock... bad idea? I was planning on using them with mid/tops ranging from 118.5hz to 20hz. Thanks
Rockin
They would be fine for what you need if you had multiples of them. I play rock through my rig. I use folded horn bottom end and the bassdrum and bass guitar sound well meaty through them. You wont get the real low frequencies with these but its not all that relevant with your type of music imo
chrismca07
Adam, you know in the hd215's which way does the driver face? surely the cone faces towards the access panel cause you wouldn't be able to put it in once you have built the cabinet. Am I right? cheers
gingerbiscuit69
no, cone is firing into cabinet, magnet in chamber. drivers mounted to the access panel side of the baffle. you can insert and remove the driver as you please.
Heathrow_B_line
Old Croc Joined: 11 January 2006 Location: United Kingdom Status: Offline Points: 7344 |
