I Need a pair of MT122s !!! |
Post Reply | Page <12 |
Author | |||
Dom
Old Croc Joined: 25 February 2004 Location: United Kingdom Status: Offline Points: 1700 |
Once more for the hard of hearing
I built 10 MT122s in one go. It is a period of my life I'd rather forget. The reason I will end up using Porn Horns in my new mid tops is because I really can't be arsed going through the hassle again. If you want to delude yourself that they are a simple build then feel free, but don't try and convince others of this. |
ceharden
I think I'd rather dive in with some fibreglass than build an MT122 out
of wood. Had enough trouble with one folded horn prototype!
Incidentally, I rebated all the joints of said horn prototype. Problem is it's so well built I can't knock it apart to try a different design! 1 day of building, hour or so of testing and it's scrap! |
Fushion Julz
Registered User Joined: 19 August 2004 Status: Offline Points: 647 |
I have built MT122s as per Rogs' plans...
They are hard...much harder than PD1850 horns...to cut and assemble.... But they are not impossible... I concur with Norty, though....For a pair of cabs I used about £90 worth of ply alone...Add screws, glues, fittings, paint, grilles (definitely needed), etc you are in for £150-£175 per pair cabinets just in material! I reckon that it took about 50hrs of actual build time to construct a pair....so let's say £10 per hr (cheap)...£500 a pair looks a bargain! |
james folkes
Old Croc Joined: 08 January 2005 Location: United Kingdom Status: Offline Points: 3064 |
the bit i am going to repeat for the benefit of everyone and anyone who
fancies these boxes is where rich points out they contain not 1 square bit of wood. everything is either trapezoidal, mitred, or extreme combinations of the two, and i mean extreme. i have the sketch alluded to in the thread "mitre angles in the mt122 flare". if anyone wants it i can probably find a way of hosting it, it does demonstrate that these angles are relevant in construction and they are not provided for you in the plans. they are by far the most complex design on this site in my humble opinion (arrogant actually, but it's only an expression). as rich says though, they do sound cool. james. |
mykey
levyte357
The 10,000 Points Club Joined: 10 May 2004 Location: UK, London Status: Offline Points: 11743 |
Cheers for that Mikey... Does the Supplier do a 2x12" Version? |
levyte357
http://www.speakerplans.com/forum/forum_posts.asp?TID=3337&a mp;PN=1&TPN=2 http://www.janaudio.com Answering your own post... Filthy habit... A man could go blind doing this... |
mykey
not mine a man called dan |
Robi-Ka
Registered User Joined: 09 March 2006 Location: Romania Status: Offline Points: 14 |
James. It would be great if you could send me the mitres of the mt122.
I'd be greatfull. Sorry for my english i'm hungarian. |
james folkes
inner vertical flare piece = 3.5 degrees.
outer vertical flare piece = 7 degrees. everything else is on the drawing, or easily calculated from what is given. if that still doesn't do it, shout and i'll try and mark up a drawing and post/ email it to you. james. |
mardy hippy.
Robi-Ka
Thanks for the info James.
Grinner
Registered User Joined: 02 December 2005 Location: essex Status: Offline Points: 407 |
has any1 used any of these horns? |
