i would like to construct horns... |
Page <12 |
sKs01 ![]() Old Croc ![]() Joined: 11 April 2008 Location: sheffield Status: Offline Points: 1744 |
a 30mm xmax will not necisarily make up for 85db efficiency im assuming your talking about car audio drivers or similar which is the only place i have seen such large xmaxes cited for a 12".
take into account the sd of the driver and more than likley the drivers your looking at wont be as desirable as an 18" on a horn in a logistical sense as many many more cabinets will be required for the same spl, add to that the low bl and qts of such drivers and you might even wind up with less controlled sound.
the punisher and lab horn are examples of well executed uses of 12" sub drivers however both have their foibles, the lab is inordinatley temprimental as in you need to be carefull with the drivers but they have low power compression and is highly efficient and has verry low fc the punisher has a much hogher fc is portable and practical however agian needs quite a few cabinets to counteract the high fc which brings cost up as the caire driver is on a par in price to that of a respectable 18" and has similar levels of power compression as its just caires 18" magnet structure strapped to a 12" cone. |
tomschute ![]() Old Croc ![]() Joined: 15 May 2006 Location: Mid Wales Status: Offline Points: 1817 |
spaceface re read the tread, and yours you have offered nothing of use, lol! There's plent of 12" drivers around with good xmax and power raeting - sorry not being picky just mis information or irrelevant threads don't help anyone. Although maybe not MASSIVE xmax. It isn't about 'moving air' with horns, whatever that's sposed to mean... I assume using a really short horn with something like the ciare sw12 might be interesting... be interesting to see how small you could make it and how many you'd need to hit 45hz Big walls of HD15s sound nice so taking it further would be interesting! Edited by tomschute - 02 July 2009 at 4:47pm |
www.stableaudio.co.uk Speaker Building Services |
ಠ_ಠ ![]() Registered User ![]() Joined: 30 June 2009 Location: Richmond, Va Status: Offline Points: 30 |
i think beat is a REALLY narrow minded concept. I just think a wall of 12s fits my needs. If perfection existed we would know about. Yea tho i think the micro size 12s would be COOL. I'm talking plastic forming and stuff not just wood (which i suspect might influence other folks choice for 18s having sore attitudes about saw dust and banged knuckles hearing 3 times as many speakers and instantly having PTSD flash backs about building wood speakers... >_>)
im just gona model some stuff and link it...
*edit* what degree in radians would you suggest i model them in? i intend to use them both outdoors in fields (this is FARM country 10 minutes to the west) and in warehouses and abandoned garages (industrial stuff to the east of me downtown)... Edited by ಠ_ಠ - 03 July 2009 at 12:11am |
tommysb ![]() Registered User ![]() Joined: 24 April 2006 Location: Finland Status: Offline Points: 1036 |
Half space. Which is 2pi steradians.
Page <12 |
