Ideal Amp for Vibe Space 12" sub? |
Zac_19
Registered User Joined: 25 December 2008 Status: Offline Points: 1 |
Posted: 25 December 2008 at 4:53pm |
Hello!
What amp would you recommend I get to power my Vibe Space 12" Sub? It is 1000w rms and 3000 peak. Here is a link to the sub: http://caraudiosecurity.com/shop/product/products_id/8295.html All help greatly appreciated! Edited by Zac_19 - 25 December 2008 at 4:54pm |
rich_gale
Old Croc Joined: 18 February 2008 Status: Offline Points: 2697 |
the best amp will be a mmats d200hc. this will give you 1200wrms at 1ohm. the d200hc is a vintage amp and they can be had quite cheap on the american ebay. you will want to look at amps that can run 1000wrms at 1ohm because 1000wrms into the 4ohm wiring will be a mightily expensive amplifier. personally, id sell the sub and replace with a high sensitivity/lower powered pro audio model. such as the ciare 12.00sw
kay-singh
Registered User Joined: 07 January 2009 Location: Slough, Berks Status: Offline Points: 69 |
depends if your happy going used?
if not, your best bet (cheapest) is running your sub at 1 ohm, and using the fusion PP-AM200010 or running it at 4 ohm (vc's in series) and using the the jbl GTO-14001e, which puts out 1200rms at 4 ohms.
