If Xmax shouldn't be exceeded, why have a Xlim? |
Page <1 23456 7> |
Author | |||
S DeXter ![]() Young Croc ![]() ![]() Joined: 12 May 2008 Location: Moon Status: Offline Points: 1268 |
I am aware of that Ian.
For tops, I have to agree 100%. For sub, I agree to differ. |
Enjoy your self...... It's later than you think.......
greeef ![]() Registered User ![]() Joined: 25 June 2009 Status: Offline Points: 128 |
I'm going to throw in my baseless opinion here.
As you drive air harder, it's elasticity and thermal compliance and all the physics stuff becomes relevant. An absolutely perfect pistonal speaker is still going to distort at high volume because it's going to get mounted in a real space, not a theoretical anechoic one, and cos that's the nature of air and ultimately, eardrums. Yes it's distortion, but it's not hard high order clipping, it bears more similarity to power compression. I'd much rather hear a dynamic system that exceeds xmax on the transients than one that used outboard processing to bring everything below xmax at the same rms level. EDIT - like above poster, i mean this applies to subs. Sounds rough on top where linearity properly matters. Edited by greeef - 25 January 2011 at 9:38pm |
IanD ![]() Registered User ![]() Joined: 17 January 2009 Location: London Status: Offline Points: 400 |
Nonlinearity due to air heating/compression is only ever an issue for compression drivers with huge power density in the throat, not in bass horns even at very high levels -- look up the numbers if you don't believe me. |
TechnoChef ![]() Registered User ![]() Joined: 23 April 2009 Location: Oxfordshire Status: Offline Points: 1109 |
From what I understand from all the above, driving a sub past xmax has more of a compression than distortion effect - like an analog tape deck. Obviously within reasonable power levels!
I've produced/written dance music for a good few years now and the best method I've found for making basslines sound Phat (with the capital P!) Is by adding a little soft tube compression. In planning for and designing subs I have always worked within xmax figures but now I think my mind has changed, maybe an extra couple of mm will add some warmth without necessarily destroying equipment??? ^^^^all for sub and nowt else though! |
I think I'm in love with your mum.
Matthias ![]() Registered User ![]() Joined: 22 July 2005 Location: Sweden Status: Offline Points: 206 |
http://www.youtube.com/watch?v=JhYtHH5JdCA
DC - displacement kills a lot of speakers. It depends on the driver, tho. It will be generated when the coil leaves the gap and the cones 0 point will shift |
Rotorbar ![]() Registered User ![]() Joined: 20 May 2009 Status: Offline Points: 71 |
This all comes down to how much you want to hear distortion and how much equipment you want to cook. Good judgment comes from experience, and experience comes from bad
judgment. You can exceed your xmax at the expense of some driver
distortion during the musical transients. Since they're transients, you
can musically get away with considerable driver distortion, so long as
the amplifiers don't clip. That's another kettle of fish. Eventually, exceeding xmax far enough, for long
enough, will rip apart the surround or burn the voice coil, and after a
recone job, you will have a new feeling for how much you can exceed
those limits. Since I go entirely with vented bass cabinets, the
mechanical limits in that 1/3rd octave above Fb get to me first. I try
to stay in the 6-10dB-down range for running power at the amplifiers. It seems to be a good trade-off between ruined voice coils and torn surrounds. As a side note, I have never had a spider fail.
In the mids/tops, I see thermal limits first. Got another lesson on
that recently. The photo's I see of burned voice coils mostly show that
some part of the coil was out of the gap. Some of them suggest poor
reconing techniques, meaning the voice coil wasn't centered magnetically
during the recone job.
The nice thing about a large xlim is having the ability to survive some monstrous transient, like when a mike gets dropped or a signal processor gets accidentally turned off. If the driver can take that transient physical abuse, great. You made it through another day. |
snowflake ![]() Old Croc ![]() Joined: 29 December 2004 Location: Bristol Status: Offline Points: 3061 |
if you read up an the psycho-acoustics of the missing fundamental this suggests that if the 2nd and 3rd harmonic distortion is in the right proportion the distortion will be indistinguishable from the fundamental and make it sound a lot louder. if a driver were designed with this in mind it will have slight asymetry in the suspension or motor field to introduce 2nd order distortion at high excursion and to keep it higher than the 3rd order distortion. as below 200Hz the human ear rapidly loses sensitivity (at 24dB/octave I think) a couple of percent distortion will make the perceived sound twice as loud.
amp clipping will not introduce the right sort of distortion to sound good so generally if you have to choose a big amp overpowering fewer speakers will sound better than a small amp clipping into a greater number of speakers. other than for subs distortion does sound terrible, especially on human voices |
+1 snowflake and rotorbar!
Edited by S DeXter - 15 February 2011 at 7:13pm |
cooky1257 ![]() Registered User ![]() Joined: 16 February 2011 Location: Wirral Status: Offline Points: 240 |
There's two halves to a waveform, if the coil is out of the gap on the upstroke then isn't the downstroke dependent on the surround and spider returning the coil to a driven position in time?. The pistonic behaviour is only guaranteed within xmax limits as I understand it. Start approaching xmech and you'll bottom your drivers, quite possibly wrecking them.
Do you mean there will be an assymetry of motion? The surround and spider are always responsible for driver position, not just out of xmax...?
Pistonic behaviour relates to cone breakup modes (cone flexing and resonating) rather than xmax effects . Loudspeaker modellers assume the driver to act like a perfect 'piston' (unless you are using FEA!). Alot of newer drivers have quite large Xmechs.... |
Mr Flemings rule only applies if the coil is in the magnetic field, so yes if hit with a huge sine wave say, it wouldn't be producing that sine wave correctly. Of course the surround and spider's job is to position the vc correctly about the 0 position with applied signal creating the +/-'movement', they are not responsible for playing the undriven parts of a tune;-) |
there is also the possibility with horn loaded subs of using the front chamber to roll-off the HF at right frequency to drastically reduce the amount of third harmonic. if the third harmonic is kept to about a third of the level of the second harmonic the distortion will sound a lot more musical. so if the horn has a low cut-off of 40 Hz it will have high excursion around 60Hz. Second harmonics of this will be 120Hz and third will be 180Hz. so if the front chamber can be sized to begin HF roll-off after 120Hz and to be at least 6dB down (in addition to the mass roll-off of the driver) at 180Hz there could be some improvement to the sound. this is all in theory BTW but will try it in my next prototype
Page <1 23456 7> |
