If you could have just 2 budget subs? |
Post Reply | Page <123> |
BJtheDJ
Young Croc Joined: 28 November 2012 Location: Bristol Status: Offline Points: 884 |
Thanks(1)
OP said "Budget options please, no £2400 each, current production Martin Audio bins.. stuff that's been about the block." So nothing wildly expensive like current Martin bins, and nothing that's had seven shades of sh!t blown out of it.
If your vaccinations were mandatory and nobody in your class had measles,
then you know that you're not a Millenial kid.</f |
FOO
Young Croc Joined: 23 December 2018 Location: Denmark Status: Offline Points: 813 |
Thanks(1)
Master Audio MD218SW with the processed 3K6 amp. Now Thats a set i would like to have
Noyzmunky
Young Croc Joined: 10 June 2005 Location: United Kingdom Status: Offline Points: 1260 |
cheers guys. I'm kinda leaning toward a pair of X1's at the moment. Nice warm response down to 30 odd hz and still viable to move about the place with just me. Twin 6bp would be great, as would three lab horns but I think size will get prohibitive.
Cheers to BJtheDJ for noticing the budget requirements. This is a project almost entirely just for my own ears so some realities need to be addressed.. So the upshot seems to be modern powered subs (out of the question given budget and set up space) or an old design of Rog that still goes the distance like the X1. I will continue trawling the net for likely contenders. |
my name is Inigo Montoya...you killed my father, prepare to die!.
jacethebase
Old Croc Joined: 23 September 2009 Location: Somerset Status: Offline Points: 5697 |
I would put money against a DV-Sub totally destroying a X1 in a similar sized cabinet.
Only disadvantage is the DV-Sub needs a adult amplifier as it’s 2.66r
Edited by jacethebase - 09 February 2020 at 10:09am |
www.stage2sound.com |
Noyzmunky
I don't doubt it, but, and it really is a big one as they are current production and... can I find two of them for less than a grand a pair? Doubtful. a pair of PD1850 loaded probuild X1's went for 500 a few weeks back. Bang for buck is there anything better? given my brief of cheap, low hz, easy to handle and not a horn. |
Meat
Old Croc Joined: 05 June 2009 Location: Manc Status: Offline Points: 1514 |
Thanks(1)
X1s are quite a big box. How important is the one man lift part of the spec... ...not sure I'd be one-man lifting them loaded with 1850s.
Noyzmunky
'quite' important from my point as I'll be taking them out of the container on sunny days while I work and I'm up there on my own mostly.
That's not to say I can't build a ramp though.. |
cravings
Thanks(1)
x1s are movable on wheels but they're not a one man lift at all.
el chupacabra
Young Croc Joined: 02 August 2006 Location: United Kingdom Status: Offline Points: 757 |
Thanks(1)
if there's a couple of arcline x still kicking about (not that many were made) - they'd be great for a lil one person rig. light, drop as low as is needed to be musical for pretty much anything, pretty efficient.
2x15" ported horn config. |
al_x
Young Croc Joined: 12 February 2006 Status: Offline Points: 834 |
Thanks(1)
X1’s with void v18-1000’s with 1.5k coming from the amp sound brutal. Even in singles.
£290 for the driver, £60 for 1 1/2 sheets of birch ply. The RC1 as mentioned are supposed to be good, a 22”(?) reflex design with 3000w rms active amp I think. But they are something like 3 or 4 grand plus vat each.
Edited by al_x - 09 February 2020 at 6:17pm |
concept-10
Young Croc Joined: 17 May 2016 Status: Offline Points: 1292 |
Someone told me the other day about a dual 12 from Thomann that is getting very good reviews, not heard it but maybe worth a look. will be cheep to.
Noyzmunky
I will have a look at the thomann stuff. it gets good reviews for budget kit. |
