  New Posts New Posts RSS Feed - Infinite 6 enough?
Infinite 6 enough?
Mark James View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mark James Quote  Post ReplyReply Direct Link To This Post Posted: 19 September 2014 at 1:02am
because the infinite 6v2 and the behringer ep2500 are not the same design amp lol :P the infinite 6 v2 when running in 4ohm sterio is a pretty awesome amp tbh itd be my first choice if i was looking for something to power 1200w into 4 ohm per side if weight and cost wasnt an issue :P infinite 8v2 iirc can happily handle 3 puns per side iirc toasty ghost????
insert silly sentence here
odc04r View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote odc04r Quote  Post ReplyReply Direct Link To This Post Posted: 19 September 2014 at 9:42am
Originally posted by Rekkah Rekkah wrote:
This is kind of confusing, why am I seeing people running 2 cabs into 4r bridge off a cheap berry ep2500 and getting good results, yet can't run it off an inf6?
Results are not always good.
Sinai Sound View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sinai Sound Quote  Post ReplyReply Direct Link To This Post Posted: 19 September 2014 at 10:06am
Just because people do it, doesn't mean it's a good idea!
I use a inf6v2 on my high mids and it sounds lovely
I'd look out for an inf8v2 or inf7v2 perhaps as this will do what you want
Rekkah View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rekkah Quote  Post ReplyReply Direct Link To This Post Posted: 19 September 2014 at 12:22pm
Thanks for that sinai really clearrd everything up. I'll keep my eye out for an inf 8 or similar.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rekkah Quote  Post ReplyReply Direct Link To This Post Posted: 23 September 2014 at 10:07pm
Because of cash flow im going to have to go with a t.amp proline 3000 for the time being. Would i be best off running 2 of these in bridge, or get the 4 ohm drivers and hang one off each channel?
Dutchman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dutchman Quote  Post ReplyReply Direct Link To This Post Posted: 16 November 2014 at 10:00pm
4 ohm per channel is better than 2 ohm per channel. So yes buy the 4 ohm drivers, damping factor will be better and the proline is a very good budget amp, spank the puns!
We need more SPL!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rekkah Quote  Post ReplyReply Direct Link To This Post Posted: 30 November 2014 at 7:37pm
Cheers Dutch, Ended up just buying an Infinite 8v2 so much less hassle and saved 6u of rack space compared to 3 prolines for 6 punishers. Using the infinite 6 to power the kicks in an xtro.
