Information on SBH (Super Bass Horns) |
Post Reply | Page 12> |
Requiem
Old Croc Joined: 20 January 2011 Location: Bristol Status: Offline Points: 1805 |
Posted: 23 August 2017 at 5:43pm |
Hi guys,
Came into possession of a big pile of these subs, loaded with Oberton xb1500 drivers and looking for some more info on them as I don't know a lot about them, mainly hi pass and low pass recommendations, spl, reviews, plans if they are available, anything really.... Cheers!
www.requiem-soundsystem.com
Custom Martin Audio WSX, USB & CSG Soundsystem based in Bristol |
munkey
Registered User Joined: 17 August 2011 Status: Offline Points: 300 |
https://forum.speakerplans.com/super-bass-horn-v-02-by-startec-quad-acousticsf_topic20503.html
Info's in there somewhere |
the midtops!
munkey
I'm guessing you've bought cartoon sounds bins. I know the builder. Nice compact bins ;)
the midtops!
munkey
the midtops!
corell
Young Croc Joined: 19 August 2013 Location: Berlin Status: Offline Points: 1161 |
High pass 28 - 32 Hz depending on stack size
Low pass 90 - 120 Hz They have a strong peak at the 1/4 lambda resonance (30-35 Hz), then a dip -sadly where the main "techno basslines" are, so dont push them to hard here! - (40-50 Hz) and then rising response from 60 Hz up. With increasing stack size, the dip becomes smaller and with 8+ bins per stack it's nearly flat. Oberton 18XB1500 is a great chassis for these horns, allthough i would want to cross it no higher than 100 Hz ideally. Compared to other FLH designes like 1850 Horn, WSX etc. these have a longer hornpath and therefor go lower at the cost of some efficiency. |
Requiem
They should hopefully always be used in either stacks of 6 or 12 with the horn mouths coupled, so the dip shouldn't be too noticeable should it, and that could be EQ'd out anyway could it not?
Thanks for the info, thats great.
munkey yes we are getting Kartoon's bins haha... my crew are going to hate me |
corell
You could EQ the dip but its at the dispersion maximum of the cabinet, so you dont have any headroom here when running near its rms power.
But either way, its a great horn, very tight yet deep sounding. Just dont expect the mega "oomph" at 40-50 Hz you would get from a Bandpass or similar tuned in this region. (not that this is preferable anyways, but most techno folks are quite used to it). Its sort of the opposite of a f218 sound wise imo. Edited by corell - 24 August 2017 at 5:45pm |
ReubGold
Registered User Joined: 09 April 2012 Location: Essex/JA Status: Offline Points: 271 |
What is actual performance like as opposed to theoretical?
People keep going on about longer horn length, but so many sell them after getting them built, must be something not right? |
If he turns me into a zombie, first person I'm coming after is you.
rosssss224
Registered User Joined: 25 July 2012 Status: Offline Points: 447 |
Think its more the fact they are bloody massive?
JEB88
Registered User Joined: 17 August 2011 Location: Norfolk Status: Offline Points: 268 |
I only sold mine because they were to big for smaller venues... massively regret it now they were the best sounding bass cabs that we've had. I would buy some more but the crew we normally do nights with have Invaders so makes more sense to get them atm.
paulus
Old Croc Joined: 14 December 2005 Location: SOUTH BIRMINGHA Status: Offline Points: 3181 |
out of interest what do you think in terms of pros and cons of invaders and sbh??apart from sbh being pretty big
TRENDSETTER SOUND SYSTEM
JEB88
I'd say the invader is bigger in terms of width. I also think its heavier and abit more awkward to move around than the sbh.
I prefer the sound of the sbh
