Innerfeild soundsystem plans |
45king
Registered User Joined: 05 November 2008 Status: Offline Points: 1 |
Posted: 05 November 2008 at 2:10am |
anybody got the plans for the innerfeild rocket sub things?
cheers
mykey
Blue Peter has them
Calculus
Young Croc Joined: 03 January 2005 Location: Newcastle Uk Status: Offline Points: 1105 |
as far as i know they were designed by a former turbo sound designer and are heavy duty Water/sewage pipe tubes... with a fibre glass bullet/rocket shape in them... Get some heavy duty pipe and design you own. wouldn't be that difficult surely. As far as i know they're the only people with them so why not email them.. they'd probably ignore you though.
Edited by Calculus - 05 November 2008 at 6:30am |
chilli
Old Croc Joined: 28 July 2004 Location: United Kingdom Status: Offline Points: 1676 |
weren't they designed by laurence dickie, i think he also designed the aspect series, although paul m will probably correct me on this...
Money can't buy you happiness, but it can allow you to be miserable in comfort.
norty303
Essentially a w-bin in the cross section.
mrchay
Young Croc Joined: 29 September 2008 Status: Offline Points: 565 |
I'v often seen that very heavy (>1inch thick) yellow plastic gas main pipe(looks around 18inch diameter).
If I was a student I'd definately be grabbing a piece of that and putting a driver in the end :-) It looks much more rigid than the black ribbed pipe, which is made from much thinner plastic. |
Caeraphym
Registered User Joined: 02 May 2008 Location: UK Status: Offline Points: 38 |
They do look like a Blue Peter vs Teh Thunderbirds audio experiment, but after many hours infront of their rig over the years I have to say it sounds even better than it looks. Nothing beats sexy rocket boobies on acid playing Nina Simone at 7:30am on top of a hill. |
Deadbeat
Old Croc Joined: 12 March 2008 Location: Singularity Status: Offline Points: 3167 |
Looks creepily like the very old Turbo gear as has been said.
Large diameter pipe (specifically sonotube) has been used for a while making subwoofers - though this is the only use I have seen as a horn - others have been resonant pipe type things with an 18" diameter and a driver in the end Anybody wanting to make something similar should look at Sonotube or similar stuff - it's the stuff they use to form concrete and should be available at a good builder's shop near you!
Away on extended leave.
norty303
IF you want to know more details about innerfield bass bins do a search for posts by RayVaughn, he used to participate quite a lot here and answered a good many questions about his bins.
boycey
Old Croc Joined: 25 June 2006 Location: Manor House Status: Offline Points: 1612 |
indeed |
the only thing more dangerous than a person who doesn't give a f**k is a person who gives a sh*t.
